05 wrangler unlimited engine light - JeepForum.com
post #1 of 6 Old 04-03-2013, 09:47 AM Thread Starter
gothamtcb23
Hey Guys or Gals
So I have a 2005 Wrangler Unlimited. It's got about 90,000 miles on it and it seems to run fine. The only thing is, my check engine light goes on a lot. Every time I run it through the computer, it comes up that the O2 Sensors need to be changed. But I have changed them at least 4 times in the past two years. So I'll change them, and then a few months later, the engine light is on again. It's frustrating and its slowly draining my wallet. Does somebody know why this happens and what I can do to fix it? Or is this just something I have to live with?
Thanks
Rich
gothamtcb23 is offline
post #2 of 6 Old 04-03-2013, 10:44 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by gothamtcb23 View Post
Hey Guys or Gals
Thanks
Rich
What specific OBD2 codes does the computer throw? Get them read for free at almost any parts store. If the codes indicate that the O2 sensor are out of range that could mean that they are working but your air fuel mix is off.
A really clogged air filter could do that. So could bad spark plugs.
Any type of air leak before the O2 sensor will set off the CEL and make the engine run rich because of a false lean condition.
Since you have pre and post cat converter O2 sensors they compare what goes into the cat and what comes out.
If the comparison does not show that the cat converters(s) did their job that may be the problem. The O2 sensor(s) are just the messenger(s). Don't kill ( or replace) the messenger!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 6 Old 04-03-2013, 12:41 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Get codes:
Key On, Key Off, Key On, Key Off, Key On then Stop! Do not go to start at any time. Codes will be displayed on the ODO.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 6 Old 04-03-2013, 01:02 PM Thread Starter
gothamtcb23
Originally Posted by FernBchJeep View Post
Get codes:
Thanks for this trick. It came out P2098.
This means Downstream Fuel Trim System 2 Lean right?
post #5 of 6 Old 04-03-2013, 01:03 PM Thread Starter
gothamtcb23
The specific codes that came up after the Key Trick were "P2098" That's Downstream Fuel Trim System 2 Lean
What do you suggest I do now?
post #6 of 6 Old 04-03-2013, 02:38 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Same situation here;
http://www.jeepforum.com/forum/f67/c...o-rich-564411/
There is some indication that this could be a software problem. Especially when the dealer does the "you have bad gas" 'two step' BS excuse.
check engine light , computer , o2 sensor , oxygen sensor , wrangler
