05 Rubicon Antifreeze boils - JeepForum.com
post #1 of 9 Old 07-01-2010, 07:26 AM Thread Starter
kin22kaid
Need help, I can hear my antifreeze boiling after driving on hot days! I have changed thermostats twice now and did a full system flush. I put fresh prestone 50/50 with water wetter and it still boils or at least that what it sounds like. Radiator is clean on the outside and is dent free. Any suggestions?
kin22kaid is offline
post #2 of 9 Old 07-01-2010, 08:58 AM
ikadesh
Sounds to me like a water pump issue. If you are not getting proper flow of water through your engine, then the motor heat is escaping through the boiling of antifreeze. That is, until all the antifreeze boils away, which usually occurs after about 20 miles of highway driving in average temperatures.
ikadesh is offline
post #3 of 9 Old 07-01-2010, 12:10 PM
greyarea
what is the gauge reading
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #4 of 9 Old 07-02-2010, 03:05 AM
oakmckinley
Somethings not right for sure, either the bottle of prestone you got wasn't 50/50 or you had alot of water in your system when you added the antifreeze and dilluted it to more like 70/30.
Ethylene Glycol boils at 390F and water at 212F, I would hope that even in hot weather your running around 220F engine temp.
Is your thermostat opening, maybe the coolant isn't getting a chance to go through the radiator?
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #5 of 9 Old 07-02-2010, 12:02 PM Thread Starter
kin22kaid
Thanks for the info! The gauge on hot days and driving on highway reads a little over an 1/8 of a inch past 210. I have only lost antifreeze 2 times now both times it was after the engine was turned off. Boiling noise and then came out the overflow.
post #6 of 9 Old 07-03-2010, 05:12 AM
RubiconBlack
My 04 Rubicon does the same thing! I was concerned about it at first but its never over heated on me and left me stranded. It usually does it after I get off the highway on really hot days and when I shut it off I can here it boiling. I haven't seen any issues with other Wranglers working at a Jeep dealership. Hope this helps.
RubiconBlack is offline
post #7 of 9 Old 07-05-2010, 06:54 AM Thread Starter
kin22kaid
Today I am going to replace the upper and lower hoses along with a new pump and while I'm at it another thermostat and refill with fresh 50/50. Hopefully the boiling stops! If not I am at a loss.
post #8 of 9 Old 07-05-2010, 11:13 AM Thread Starter
kin22kaid
At my auto parts store I was talking to a guy at the counter and he talked me into replacing the cap and burping the system. Thank God that worked!!!! The lower seal on the cap was cracked and that let air into the system. Thanks for everyone's help!
post #9 of 9 Old 07-05-2010, 07:51 PM
RubiconBlack
Awesome glad to hear your problem is fixed!
coolant , antifreeze , boil , rubicon , TJ , 4.0
RV antifreeze to balance tires....... Eaallred Tires & Wheels 4 02-22-2010 10:14 PM
Disposing of Antifreeze TheDustMan Engines & Drivetrain 9 12-07-2009 01:09 PM
07 17" Rubicon Wheels and Tires on an 06 Rubicon airems Tires & Wheels 2 10-01-2008 05:16 PM
Disposing of Antifreeze (Where?) Rubi22 General Jeep & Off-Road Equipment 10 03-27-2008 10:17 AM
What is the normal pH for antifreeze? jzmtl Engines & Drivetrain 4 05-02-2007 06:42 PM
