03 Liberty Oil Pan Removal Procedure - JeepForum.com
post #1 of 5 Old 04-17-2012, 07:12 PM Thread Starter
03NYLibSport
2003 KJ Liberty
Hello all, this is my first posting...and thanks in advance for any assistance you can provide. I bought my 03 Liberty at an auction last year and it recently started leaking oil from the oil pan which has rusted out badly - layers of the metal are flaking off. The maintenance manual says to remove the engine in order to remove the oil pan. Is there a "less involved" procedure to remove/replace the oil pan without having to remove the engine?
If so, please share the procedure and advise of any precautions / safety steps I should use...thanks.
03NYLibSport is offline
post #2 of 5 Old 04-17-2012, 07:40 PM
tjkj2002
2002 KJ Liberty
You either have to pull the engine or support it from above(via engine support bar or cherry picker) and drop the cradle with the front diff,rack&pinion,and front suspension.
tjkj2002 is offline
post #3 of 5 Old 04-17-2012, 10:20 PM
chevyblazer5150
Those are your choices. One of the MANY reasons I sold my liberty. Too bad jeep didn't make them better.
1995 Grand Cherokee Laredo, V8, 242 T-case swap, custom driveshafts, bumpers/rock sliders, X20 8000# winch, Rough country long arm kit w/5.5" rustys springs, full Detroit rear locker, HP D30/trutrack, 4:11 gears 32x11.5x15 Maxxis MT's
chevyblazer5150 is offline
post #4 of 5 Old 04-22-2012, 12:26 PM Thread Starter
03NYLibSport
2003 KJ Liberty
Oil pan replacement
Hello TKY and Chevy,
Thanks for the feedback...I figured there had to be another way other than removing the engine although I was hoping that the alternative wouldn't be this involved. Looks like I have my work cut-out for me...thanks again for the info.
post #5 of 5 Old 04-22-2012, 07:11 PM
mrowaan
It can be changed in the jeep.If you pull the diff you don't have to pull the engine.
Flexing my WJ http://www.youtube.com/watch?v=KWFDAaQyMlM
mrowaan is offline
2003 , liberty , oil pan , removal
Broken Bolt removal procedure AMCMasterTech Engines & Drivetrain 10 03-01-2012 06:34 PM
Removal of radio - 2005 Liberty Mark1968 Audio, CB & Ham Radios, GPS, & Electrical 2 04-24-2010 11:58 AM
Painting Procedure kirkhbauer General Jeep & Off-Road Equipment 13 02-26-2008 11:13 PM
Procedure for putting in/taking out TB? Jeff9 Street Jeep Forum 3 01-12-2008 05:34 PM
2004 Liberty Door panel removal? Ozaxeman Audio, CB & Ham Radios, GPS, & Electrical 3 11-22-2005 03:50 AM
