-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   03 Liberty Oil Pan Removal Procedure (http://www.jeepforum.com/forum/f19/03-liberty-oil-pan-removal-procedure-1358057/)
03NYLibSport 04-17-2012 06:12 PM
Hello all, this is my first posting...and thanks in advance for any assistance you can provide. I bought my 03 Liberty at an auction last year and it recently started leaking oil from the oil pan which has rusted out badly - layers of the metal are flaking off. The maintenance manual says to remove the engine in order to remove the oil pan. Is there a "less involved" procedure to remove/replace the oil pan without having to remove the engine?
If so, please share the procedure and advise of any precautions / safety steps I should use...thanks.
tjkj2002 04-17-2012 06:40 PM
You either have to pull the engine or support it from above(via engine support bar or cherry picker) and drop the cradle with the front diff,rack&pinion,and front suspension.
chevyblazer5150 04-17-2012 09:20 PM
Those are your choices. One of the MANY reasons I sold my liberty. Too bad jeep didn't make them better.
03NYLibSport 04-22-2012 11:26 AM
Oil pan replacement
Hello TKY and Chevy,
Thanks for the feedback...I figured there had to be another way other than removing the engine although I was hoping that the alternative wouldn't be this involved. Looks like I have my work cut-out for me...thanks again for the info.
mrowaan 04-22-2012 06:11 PM
It can be changed in the jeep.If you pull the diff you don't have to pull the engine.
The time now is 11:29 AM.
