Whats your MPG? - Page 2 - JeepForum.com
 1Likes
post #16 of 56 Old 07-28-2013, 07:00 AM
mason93
Stock 04 rubicon. I have seen anywhere from 15.something up to 18.something based on how and where I was driving
crabbyt likes this.
mason93 is offline
post #17 of 56 Old 07-29-2013, 05:19 PM Thread Starter
RhinoChaser
Originally Posted by underpowered
15 miles south of covington. but you are correct, last city in KY before you cross the river.
I'm currently living on the Kentucky Indiana border, between Owensboro and Tell City. Here for work for another few months, than its back to So Cal. Fun to find some local jeepers.
RhinoChaser is offline
post #18 of 56 Old 07-31-2013, 01:11 PM
9859limited
98 5.9 limited. 5.9liter v8, 46re, and a 249 transfer case getting 15-17 mpg average the past month.
9859limited is offline
post #19 of 56 Old 07-31-2013, 06:14 PM
JGC12USMC
2012 JGC with a 5.7 hemi. Tires are Michelin Latitude Tour 265/60R 18. My mpg's are usually around 18.5 city and 21.5 on the highway.
JGC12USMC is offline
post #20 of 56 Old 08-01-2013, 11:23 PM
jjvw
jjvw's Avatar
Stock '03 Rubicon with 32" BFGs.
My record so far is 20.38mpg. Last tank was 17.2mpg. I typically get 14-18 depending on how much highway driving I do.
Driving with ODBII & Torque showing the current live milage helps a lot. You get to see how the Jeep is performing in real time. I've been able to learn where my shifts should happen and that I should use 5th gear to cruise more often.
I have high hopes for this current tank. I filled up in Leadville and drove 100 miles / 5,000ft downhill to Denver and only used a 1/4 tank!
2003 Rubicon
jjvw is offline
post #21 of 56 Old 08-08-2013, 08:30 PM
swirve
2000 TJ. 4.0 5speed. 33 12.50 15's 3.25" lift. Just filled up today, 17.1 mpg
swirve is offline
post #22 of 56 Old 08-13-2013, 08:43 AM
RowJ
Originally Posted by jjvw View Post
..... I filled up in Leadville and drove 100 miles / 5,000ft downhill to Denver and only used a 1/4 tank!
Should be a worlds record!
98 TJ with 4.0L engine
4.5" lift on 33/12.5/16's at 28 psi
4.56 gears and top off for the summer.....
Got never better than 13.75 for first yr I owned it, till I realized my factory original Viscous Fan Clutch was dragging some.
Now 14.75 mpg local, 16 mpg on hwy trip!
RowJ is offline
post #23 of 56 Old 08-13-2013, 09:03 AM
jjvw
jjvw's Avatar
Sadly, I ONLY got a little over 18mpg on that tank. But I finished it off with mostly city driving. Not my best. What does surprise me is that I can take a 25-30 mile detour/shortcut over a very slow rocky mining road and still often average 13-15 mpg on that same tank. Keep in mind that I am still at stock height with 32" tires.
2003 Rubicon
jjvw is offline
post #24 of 56 Old 08-16-2013, 09:50 PM
Spud100
2.5 4 cyl, 31s, 4:10 gears= 14-15 mpg
Spud100 is offline
post #25 of 56 Old 08-16-2013, 10:17 PM
jjvw
jjvw's Avatar
Just to add to my statement above, I filled up today after a tank that included about 100 miles of mountain highway driving, 30 miles of Denver flat highway, 60 miles of city, and 30 miles of rocky mining roads mostly in 4L that climbed up 3,000 ft and back down before hitting normal roads.
16.64 mpg
2003 Rubicon
jjvw is offline
post #26 of 56 Old 09-02-2013, 11:34 PM
Leyva_WJawd
Are you guys calculated it yourself or using the overhead console read out? I'm getting about 15 mpg city and highway combined. Just calculated after killing a full tank. Honestly, with AWD and a 4.7l V8 I was expecting worst.
1999 Grand Cherokee Limited, 4.7L V8, QT II, AWD, Brush Guard, 31x10.5x15"s. BB otw.
Leyva_WJawd is offline
post #27 of 56 Old 09-08-2013, 09:31 PM
9859limited
I hand calculated mine and the over head was within .1mpg
post #28 of 56 Old 09-08-2013, 09:36 PM
KreepyCrawler
1990 YJ 2.5L 4.88's 35's 12-17 mpg's depending on if Im driving like a maniac or normally. And by maniac I mean the speed limit.
KreepyCrawler is offline
post #29 of 56 Old 09-08-2013, 09:59 PM
462FSJ
1973 J-Series Truck
73 j4000 big block 454 bored 30 over to 462. polished heads built internals edelbrock proformer series 4 bbl 750 cfm, msd ignition coil distributor and wires, holley performance fuel pump, billet aluminum radiator, th400 tranny. stock tire size.. soon to come 33s as im sure im leaving out more info.... 10 mpg.. on a good day haha
462FSJ is offline
post #30 of 56 Old 09-08-2013, 10:04 PM
swirve
Thats actually not too bad for a motor like that
swirve is offline
