What's your Jeep's Top Speed?!!?? - Page 8 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > What's your Jeep's Top Speed?!!??
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-07-2008, 04:28 PM   #106
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
My xj used todo 115+ It took 3 days to get there but it woudl do it...It woudl bring the speedo down and touch it on the bottom of the housing....
Now, It will do about 75....That is screeming at like 5-6000 r's lol 5.13s FTL lol
oh and with the boggers on it anything over 50 is scarry....
Arcticcat843 is offline   Reply With Quote Quick reply to this message
Unread 12-07-2008, 04:54 PM   #107
xtreampyro
Originally Posted by ilikedirt View Post
Its possible with the turbo flux capacitor while running high octane blinker fluid. The best have it.
Me and one of my friends actually convinced a kid that he needed to change the blinker fluid on his saab 95
02 TJ 4.0, 6" Clayton LA's, HP D44 Eaton, Sterling 10.25 Detroit, SniperFab Flares/Rock Sliders
xtreampyro is offline   Reply With Quote Quick reply to this message
Unread 12-07-2008, 05:30 PM   #108
alexrule123
Originally Posted by n20jeep View Post
you're right... I never made it that high
Thank you good sir for being honest
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 12-07-2008, 06:47 PM   #109
n20jeep
1993 XJ Cherokee
one day though...i WILL break the speed limit
n20jeep is offline   Reply With Quote Quick reply to this message
Unread 12-08-2008, 07:52 PM   #110
alexrule123
Maybe in a 35 zone
May 2013 COTM
Unread 12-08-2008, 07:57 PM   #111
neatocj
1981 CJ5
I got my cj to do 113.....its not a race car just a 351c.
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline   Reply With Quote Quick reply to this message
Unread 12-09-2008, 10:51 AM   #112
seanyb505
1997 XJ Cherokee
Bounced off the governor, where ever that is. 113-116.
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
www.jeepstrokers.com
seanyb505 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2008, 06:54 PM   #113
riggsracin
i had a tj to 80 mph and it felt fine
riggsracin is offline   Reply With Quote Quick reply to this message
Unread 12-19-2008, 03:19 PM   #114
freeburg
1987 MJ Comanche
had the 5.2 ZJ to 135 the 5.9 Zj has hit 150 the 87 MJ tops out at 80 (long time)
and when done the 90 MJ should top out 160-170
87 MJ 2.5 5spd 6.5" 34"TSL D30/8.8 4.88's
D44/9in(spool)5.13s redoing then putting back on the comanche maybe....
freeburg is offline   Reply With Quote Quick reply to this message
Unread 12-19-2008, 03:59 PM   #115
sliseno
i had my 99 tj up to 95. drove for maybe 10 miles..no problem.
Roads? Where were going, we don't need...roads!
sliseno is offline   Reply With Quote Quick reply to this message
Unread 12-19-2008, 04:30 PM   #116
SoloCamo
1988 MJ Comanche
Specs?
10 char
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline   Reply With Quote Quick reply to this message
Unread 12-19-2008, 07:38 PM   #117
Brizio
1991 FSJ Wagoneer
110 with a Cherokee Turbo Diesel
85 with a Grand Wagoneer
Brizio is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 09:37 AM   #118
freeburg
1987 MJ Comanche
Originally Posted by SoloCamo View Post
Specs?
10 char
mopar performance PCM
95 octance gas
KRC 210X camshaft
2.02 street port R/T heads
crower SS rockers 1.7 ratio
turbo city dual intake
Unread 12-20-2008, 09:38 AM   #119
MudDuck99
2014 JK Wrangler
i hit eighty once...never again
MudDuck99 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 09:52 AM   #120
jeepdude1
how fast
ive only got mine up to 75, but got a ticket for it
jeepdude1 is offline   Reply With Quote Quick reply to this message
