What performance mods have you done? - JeepForum.com
post #1 of 48 Old 08-05-2007, 09:11 PM Thread Starter
skenzer
skenzer's Avatar
OK
I've been getting into doing some performance mods to my rig and without spending thousands of dollars. This has been more of a "hobby" so to speak. Here's what I have bolted on so far....
K&N FIPK
Magnaflow Cat-back...without the cat (I say BS to those that say no cat makes no difference in power)
Bored out TBI to 63mm
Tried the Hypertec Power Programmer III and I thought it really sucked. Did nothing for me at all except trigger a check engine light.
Except for the Hypertec POS, I'm liking the mods I've done..very noticeable change in power and yet a little better gas mileage.
What have you done so far? and what have you liked and not liked?
2001 Cherokee Limited
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
Lot's more to do....
skenzer is offline
post #2 of 48 Old 08-05-2007, 09:46 PM
urban-yan
urban-yan's Avatar
Under the Hood
- Magnum aFe® Stage 2 Intake System
- 62mm Throttle Body
- 63mm Delrin 3/8" Throttle Body Spacer
- Mopar Transmission Oil Cooler
- BANKS TorqueTubes® header/ 2000°F Hot Jet Coated
- Magnaflow 2.5" Polished Muffler/ Cat/ Double Wall Tip
- Dodge Dakota Rebuilt 140+amp alternator
The afe intake and 62mm TB were worth the investment. The banks header is pretty sweet too albeit pricey when you factor in the hot-jet coating and installation. The TB spacer is useless as was the Jet Stage 1 chip I just sold. The magnaflow muffler isn't bad, but if all goes well it will be replaced by some goodies fashioned by our resident turbo guru - Bryson.
Handling Upgrades
- 300MM PBR 2 Piston/Slotted/Cryo-treated Front Brake kit
- Teraflex Rear Disc Conversion
- Addco F+R sway bars
- Bilstein HD Shocks
I'm pleased with most every upgrade aside from some gripes with the teraflex kit. The rotors didn't come coated so the hats rusted within a week, and since the kit was originally made for TJs, it didn't come with any e-brake cables. The 300mm front brakes were worth the investment although I often wish they were cheaper. The cryo treatment on the front rotors was worth every penny... both the front and rear brakes were installed at the same time and whereas the rear rotor hats are rusted, the front rotors look good as new.
urban-yan is offline
post #3 of 48 Old 08-05-2007, 10:04 PM Thread Starter
skenzer
skenzer's Avatar
Originally Posted by urban-yan
Under the Hood
Handling Upgrades
The word Jealous comes to my mind right now....
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #4 of 48 Old 08-05-2007, 10:50 PM
alexrule123
alexrule123's Avatar
My mods are in my sig, but here goes...
Engine
Custom homemade/ ghetto rigged intake
IAT sensor relocation mod
Bored 60mm throttle body
60 mm throttle body spacer
Upgraded ignition system
Transmission cooler
Dynomax cat-back
Magnaflow high flow cat
Pacesetter header (waiting to be installed...still...)
Handling upgrades
Front and rear Addco sway bars
I am sure I am leaving something out...but oh well
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #5 of 48 Old 08-05-2007, 11:50 PM Thread Starter
skenzer
skenzer's Avatar
Engine
Transmission cooler
Dynomax cat-back
Handling upgrades
Nice rig What do you think about those Addco sway bars?
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #6 of 48 Old 08-06-2007, 06:04 AM
Ivanito
Ivanito's Avatar
Engine:
custom air intake
60mm TB
TB spacer
99+ intake manifold
APN Header
Flowmaster 40 catback
deleted clutch fan
tranny cooler
relocated IAT
GC alternator (130amp? I think)
Handling:
WJ LCAs
Addco front swaybar
bilstein shocks
Addco swaybar for sale
Ivanito is offline
post #7 of 48 Old 08-06-2007, 06:23 AM Thread Starter
skenzer
skenzer's Avatar
Originally Posted by Dragisco
Engine:
custom air intake
60mm TB
TB spacer
99+ intake manifold
APN Header
deleted clutch fan
tranny cooler
relocated IAT
Handling:
WJ LCAs
Addco front swaybar
bilstein shocks
Cool....I like the "relocated" CAT....nice touch.
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #8 of 48 Old 08-06-2007, 08:57 AM
alexrule123
they make a huge difference
post #9 of 48 Old 08-06-2007, 09:25 AM Thread Starter
skenzer
skenzer's Avatar
I looked at Addco's website and I'm a bit confused. It basically shows that they have both a rear and front sway bar replacement for XJ's but they're showing it's not for the Limited. I can't understand that as I don't see where the XJ limited would be any different?
-b
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #10 of 48 Old 08-06-2007, 10:53 AM
alexrule123
-b
it shouldn't be different
post #11 of 48 Old 08-06-2007, 01:21 PM
Blackspike85
Not sure what models but some XJ's came without a rear sway bar
1995 ZJ Limited 4.0 Bored Throttle Body, High Flow Cat, Thrush Welded Muffler, V8 Tail Pipe, Cobra 25 CB, 4' FireStik Antenna
Blackspike85 is offline
post #12 of 48 Old 08-06-2007, 02:50 PM
skyjacked94xj
skyjacked94xj's Avatar
My mods are also in my Sig but:
-Custom intake
-62mm Bored Throttle Body
-60mm AEM TB spacer bored to 62mm
-Dynomax Cat-back exhaust
-Firepower Ignition kit
-DUI LiveWires
-Firepower Cap and Rotor
-Screamin' Demon Ignition Coil
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline
post #13 of 48 Old 08-06-2007, 02:52 PM Thread Starter
skenzer
skenzer's Avatar
-Custom intake
-DUI LiveWires
Cool. You mention a custom intake....can you give me some more details on that?
thanks
B
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #14 of 48 Old 08-06-2007, 03:23 PM
Rasta_Coty
rustys intake tube w/ 9in k&n
flowmaster reg. 40
zip tie shifter mod
99+ intake manifold swap
bored tb
tb spacer
then i changed to offroad and the list goes on..
1996 Jeep Cherokee || 4.5 in. RC || 4.0 liter I-6 high output || 33 x 12.50 BFG All Terrain T/A KO, 16x8 American Racing rims || Rusty's Air Tube w/ K&N 9in. Cone Filter || Throttle Body Spacer || Bored TB || Flowmaster Regular 40 || 99+ Intake Manifold Swap || Auto Meter (Trans Temp. | Water Temp. | Volt) Gauges || Pioneer 5800 HU || Hifonics 1606 Amp || (2) Kicker Comp Cvr 15's || 1/0ga. wiring || Vented box || Yellow Top || Tranny Cooler || Bushwackers ||
Updated 2/4/07
Rasta_Coty is offline
post #15 of 48 Old 08-06-2007, 03:26 PM Thread Starter
skenzer
skenzer's Avatar
flowmaster reg. 40
zip tie shifter mod
bored tb
tb spacer
Cool, i'm going to have to look into this zip tie shifter mod...
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
"Performance chips" OBD2 plug in fpr 4.O L6, jet performance, whats the deal? jamoka3 Audio, CB & Ham Radios, GPS, & Electrical 6 10-27-2009 11:35 AM
AMC 258 I6 performance mods byxbejer Engines & Drivetrain 2 05-18-2008 08:33 AM
Performance? FXSTCHEWY Tires & Wheels 1 12-14-2006 10:29 AM
CB performance Highlander357 Audio, CB & Ham Radios, GPS, & Electrical 12 12-13-2005 10:13 AM
anybody rebuild there 4cyl with performance mods? GREGDOG95YJ Engines & Drivetrain 6 07-24-2002 06:26 PM
