Wacky Steering - JeepForum.com
post #1 of 2 Old 09-07-2012, 03:55 PM Thread Starter
iggys
Wacky Steering
New to the CJ7 world and trying to end the "white knuckle" steering quality of my new-to-me '86. I know that it has been lifted 2.5" by spring and .5" from a 4" shackle. I want to replace the 4" shackles with stock 3" (greasable type?) to return the front castor and to level the rear pinion which is pointing slightly "up". Does this sound plausible? I've also looked into shimming as well. The jeep does have 33" tires. Been studying all the forums here with much satisfaction and have learned ALOT in a short time. Thanks to you All.
Iggy
iggys is offline
post #2 of 2 Old 07-08-2013, 08:13 AM
GTNMUDY
I'm suprised that no one has posted to your post.
I have a 84, CJ7 with 33 and a 3" lift, manual steering. I have over 220K on the jeep and have replaced my steering gear box twice. If you have a manual steering on your jeep you may need a new gear box.
It is simple to check, have someone move the steering wheel side to side while you look at the pitman arm. If you see any side to side movement of the shaft at the bottom of the gearbox you need to replace it.
Dont mess with the rear end shims. I had to add a 3 degree shim to mine to keep the U joints from failing every 5k miles. The lift and the 33's will make your ride a little squirelly.
Also check you tire wear. I run about 25lbs of pressure in my 33's. I drive over some dirt and then check the coverage of the dirt on the tread. If I dont see all the thread on the tires covered I adjust pressure untill my tires are running flat on the road.
Of course other things may need to be looked at. tie rod ends, ball joints, sway bar etc, may also cause white knuckle driving.
Since you didnt tell us what is really going on I can only give you my experience with my 84.
Hope this helps.
Good luck
Larry
GTNMUDY is offline
Wacky Ignition in my 2002 Liberty roman898 Engines & Drivetrain 1 12-05-2008 10:32 AM
Steering Box help ericcanning Tires & Wheels 0 02-28-2008 09:02 AM
Steering help please? Spike Angle Tires & Wheels 5 04-18-2007 05:09 PM
wj steering on a tj txjeep03tj General Jeep & Off-Road Equipment 5 10-26-2005 12:27 AM
Wacky whip........ 175MM BULLDOG Audio, CB & Ham Radios, GPS, & Electrical 4 10-13-2005 11:17 AM
