Unable to Get Brakes to work - JeepForum.com
post #1 of 5 Old 05-19-2012, 07:35 AM Thread Starter
thriftyninja
1975 CJ5
I have tried replacing my master cylinder, proportioning valve, brake lines for front only, Brake Wheel Cylinder, and the drum shoes. I am able to get all the lines to bleed, but no pressure is being built. I have searched many times for a leak, but I do not see any. Any ideas what could cause the brakes to not build pressure?
I have Drum Brakes front and back.
thriftyninja is offline
post #2 of 5 Old 05-26-2012, 06:47 AM
mustanggt
Try your booster
mustanggt is offline
post #3 of 5 Old 06-03-2012, 08:52 AM Thread Starter
thriftyninja
1975 CJ5
I do not have a booster
post #4 of 5 Old 06-11-2012, 12:36 PM
mrclark25
1994 ZJ
You have no brake booster? If you dont, you will really have to nail the brake pedal when you want to stop. I'm talking almost standing on the pedal to make it stop quickly.
|_|0|_|
|_|_|0|
|0|0|0|
mrclark25 is offline
post #5 of 5 Old 11-08-2012, 08:51 AM Thread Starter
thriftyninja
1975 CJ5
Figured it out. Helps when you adjust the back brakes
Brakes do not work good until they heat up, help! Tmblack3 General Jeep & Off-Road Equipment 9 07-05-2011 07:39 AM
Brakes dont work TJorange Engines & Drivetrain 4 05-11-2011 10:34 AM
Unable to get an SWR reading on new CB? Arizona98TJ Audio, CB & Ham Radios, GPS, & Electrical 22 07-23-2009 02:31 PM
Brakes don't work after lift tommy4902 Tires & Wheels 7 03-17-2006 03:40 PM
installed 3'' body lift, brakes don't work timhall Tires & Wheels 4 09-16-2004 11:00 PM
