Towing - JeepForum.com
post #1 of 6 Old 05-11-2012, 02:27 PM Thread Starter
caiha
Towing
What's the proper way to flat tow a jeep unl x. Or on a uhaul trailer with rear wheels on ground.
caiha is offline
post #2 of 6 Old 06-18-2012, 09:11 PM
VietVet67
Transfer case in Neutral--if not on a trailer you need lights too and saftey chains-
Silver Jeep club member #76 Semper -Fi my brothers
VietVet67 is offline
post #3 of 6 Old 06-18-2012, 09:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
And the transmission in Park (automatic) or in gear (manual) for flat towing.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 6 Old 07-08-2013, 01:47 PM
GTNMUDY
If older Jeep with a Dana 300 transfer case.
You need to disconnect the rear drive shaft at the rear axle.
Dana 300 does not have anyway of lubricating the rear output bearing while being towed.
Larry
GTNMUDY is offline
post #5 of 6 Old 07-08-2013, 02:06 PM Thread Starter
caiha
Larry
I have 09 wrangler. Can I flat tow or do I need a trailer.
caiha is offline
post #6 of 6 Old 07-08-2013, 02:42 PM
GTNMUDY
Your jeep is not hat old.. Look in your user manual for towing instructions.
If you flat tow make sure your steering wheel is unlocked, the front wheels need to follow a turn. If they are locked you will wear out the front tires quickly.
Larry
GTNMUDY is offline
