speed problem - JeepForum.com
post #1 of 2 Old 05-21-2012, 05:31 PM Thread Starter
comancheCory
speed problem
My Jeep comanche is only getting up to 25mph then the RPMs go threw the roof tranny fluid is fine this problem started right after I power washed the right side wheel well i'm order to weld the power steering gear box in place seeing as the bolts kept snapping and breaking causing me to lose steering. Anyideas in what the problem could be? Its an automatic
comancheCory is offline
post #2 of 2 Old 05-24-2012, 11:41 PM
scottys94XJ
check your throttle body gasket ...aloso make shur u dident soak eney computer componets...checck crank sencor...and if spped...perhaps cluch?...give moar details pls
scottys94XJ is offline
