Soft Top Wind Slap - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > Soft Top Wind Slap
Grizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! BroughYukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 07-26-2014, 08:22 PM   #1
Barkoff
Soft Top Wind Slap
Is there a remedy from the deafening wind slap of a soft top on the highways?
Has anyone been able to get rid of this with a roof rack and wind-guard?
Thank you.
Barkoff is offline   Reply With Quote Quick reply to this message
Unread 07-27-2014, 09:31 AM   #2
Oldjeepman
I put in a bestop liner helped a lot. and having the windows up help too..
Oldjeepman is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 12:55 PM   #3
trailboss
What year is your Jeep? I know some of the earlier Wrangler tops were more prone to whipping, but after some slight redesigns in the later models they got a lot better. Plus, the older the top, the more stretched out it will be: very hard to tighten up and quiet down. Maybe try a Top Prop to add some tension to the top? And a liner would probably help a lot as well...
2002 Wrangler "X".
An educated, armed populace cannot be enslaved.
trailboss is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 01:00 PM   #4
newman_buddy
If you put the AC or Heat or whatever on it will pressurize the inside of the jeep and stop the flapping. The way you can see this happening is, get in your jeep with the windows closed and the vents off. Look in your drivers side rear view at the side windows of the soft top, they will look loose and floppy. Now turn on the vents in the jeep and look in the rear view, you will see your windows start to bulge out. Once they bulge out that should cut down on a lot of the flap.
Yellow Jeep Club - #34
LJ Owners - #34
2006 6,742 Unlimited Rubicon's made
newman_buddy is offline   Reply With Quote Quick reply to this message
Unread 07-30-2014, 10:24 PM   #5
Barkoff
The jeep is a 2003 Rubicon, but it has been out of the sun since new, only has 5K miles, damn near showroom condition, the top is also like new, but there is a pretty good gap where the soft-top meets the tailgate.
Unread 07-31-2014, 08:24 AM   #6
gregstudeny
Try flipping the tailgate bar upside down from its current position.
gregstudeny is offline   Reply With Quote Quick reply to this message
Unread 08-08-2014, 09:17 PM   #7
Spud100
I concur that running the a/c or heat blower with windows up. Also, I changed to a frameless top and it really helped in that area
Spud100 is offline   Reply With Quote Quick reply to this message
Unread 08-08-2014, 09:20 PM   #8
gregstudeny
Really? I think my trek top is louder than my OEM top. I miss it.
