Rear Breaks (or axle?) Clunking - JeepForum.com
post #1 of 20 Old 05-19-2006, 12:43 PM Thread Starter
agie
Ok, after going through 10 pages of old posts and looking through my repair manual, I can't figure out my problem.
It's only happened 3 times, twice yesterday and once today. I was driving down my driveway and I felt/heard clunking coming from the rear of my Jeep. It happened when I backed up to leave a parking lot, and it happened when I braked this morning on my driveway for a passing car.
I replaced the front disc breaks about a year ago, so it's not that, plus I'm 100% certain that it's coming from the back.
Any help on this ASAP would be great, it's finals week and I'd like to get to them on time!
oh yeah, I heard the back breaks squeaking when I was breaking downhill on my driveway this morning after washing it. (totally off topic, but if your black bumpers and door handles are looking dull, add some of that Armor-All black chrome stuff to it, totally makes it look like you drove it off the lot!)
98 Cherokee 2WD 4.0 L I 6 Stock everything (Someday I'll get my dream Jeep!)
agie is offline
post #2 of 20 Old 05-19-2006, 12:59 PM
Rock Kustoms
Rock Kustoms's Avatar
wet brakes can squeek, as far as the clunck, climb under and start shaking things, report back
Rock Kustoms is offline
post #3 of 20 Old 05-19-2006, 01:08 PM Thread Starter
agie
Sir, yes Sir!
Everything looks normal, nothing is loose or falling off. It's quite dirty under there though...it'd be nice to get all of the winter dirt/sand out of there and make it look new. but that doesn't matter right now.
agie is offline
post #4 of 20 Old 05-19-2006, 02:46 PM
Rock Kustoms
hmmmmm, ok, so this clunking, i doubt its the break they dont usually clunk
when does it clunk, does it do it when your on and off the gas, hitting bumps....etc
post #5 of 20 Old 05-19-2006, 03:07 PM Thread Starter
agie
when I'm off the gas. and it's done it on pavement and gravel.
agie is offline
post #6 of 20 Old 05-19-2006, 03:19 PM
Rock Kustoms
hmmmmm
try to get some more details on when it does it, its real hard to figure out what a clunk is over the inet
post #7 of 20 Old 05-19-2006, 03:37 PM Thread Starter
agie
will do. thanks for trying to help though. if it does it again, I'll post again in more detail now that I know what I'm listening for. hopefully it's nothing serious!
agie is offline
post #8 of 20 Old 05-19-2006, 06:26 PM
alexrule123
alexrule123's Avatar
Mine kinda clunks (but not real loud) when i let off the gas, been that way for a while now...don't know if thats good or bad
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #9 of 20 Old 05-19-2006, 08:57 PM Thread Starter
agie
It happened again when I backed up to leave work, and when I rolled down a small hill. it's coming from the back, it's a grinding noise and it's kind of bumpy.
it only happens when I first start driving, it doesn't do it after I get rolling. I hope it doesn't need a costly fix, I'm a poor college student! And I hope I don't have to take it in to the dealership, there's no way I'm going to get caught driving a cheap rental POS.
agie is offline
post #10 of 20 Old 05-19-2006, 11:30 PM
Rock Kustoms
mine ticks as a start to go, its the front output bearing in the transfer case, im just too lazy to fix it (4+ hr job)
clunkin when getting off the gas is usually a rear driveshaft u joint
post #11 of 20 Old 05-20-2006, 11:10 AM Thread Starter
agie
My dad said that it could be the differential. awesome. not...
agie is offline
post #12 of 20 Old 05-20-2006, 01:45 PM
1986Comanche
1986 MJ Comanche
Maybe your breaks are broke...
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline
post #13 of 20 Old 05-20-2006, 03:07 PM
Rock Kustoms
its about 99% NOT your diff
i dunno what it is, but when it starts to do it more, hopefully itll be easier to track down
post #14 of 20 Old 05-21-2006, 05:25 PM Thread Starter
agie
My dad looked at it yesterday, and he said it's most likely the U-Joint like you said.
And now it's not doing it. Whatever...
agie is offline
post #15 of 20 Old 05-21-2006, 05:31 PM
isezumi00
isezumi00's Avatar
MOst likely a U joint....If youve mashed your skinny pedal too much what can happen is you blow the retaining clip and cap off one or more of the ends of the Joint. Then the ear floats in the yoke and any time you change direction it taps on side or the other. You can technically run with it for a very long time, but youll eventually need to replace it before it ruins the yoke.
'91 XJ Laredo
Rustys 3" Coils Frankenleef rears||DT3000 shocks||JKS Quicker DQ
Optima Red Top||Mixin' match 31x10.5x15|| Rusty's HD Trac Bar
isezumi00 is offline
2wd Rear Axle to 4wd Rear Axle Swap awilkie Engines & Drivetrain 1 01-20-2009 01:49 PM
Clunking coming from rear.. 98kkk Engines & Drivetrain 6 06-22-2006 08:57 PM
Rear Axle???? 2002XCrwlr Engines & Drivetrain 3 05-15-2006 12:27 PM
I got my new rear axle! webdr Engines & Drivetrain 2 05-13-2006 08:13 PM
T5 - What breaks first? tomass15 General Jeep & Off-Road Equipment 0 09-19-2005 11:32 AM
