#16 | |
Resident Audio Guru
... I took a v6 Maxima to 50mph, and as soon as the 3rd gear shift happened, i practically stopped accelerating
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#17 | |
Brian- 99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears |
#18 | |
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's. Projected date of completion - lol www.jeepstrokers.com |
#19 | ||
hold on a sec man. third gear is a dog? in my XJ, i do pretty decent off the line, even with 31's, and then 2nd gear is pretty good, i can take it all the way up to 60-65...i usually shift at around 60 mph(i dont have a tach). then, when i get into 3rd gear, well....i think that is my power gear.....in 3rd gear i can start out at like 35-40 mph, and take it all the way up to 100 mph....and it does it pretty quick too.
| 98 Jeep Cherokee | 4.0L Straight Six | AX-15 5-Speed | NP 231 | Dana 30 | Chrysler 8.25-29 Spline | | Old Man Emu 3" Heavy Duty Spring Rate | Alpine CDA-9853 | Uniden 520XL CB | K40 Antenna (56" Whip) | RLF CB Mount | Flowmaster Super 44 | Duals | | AR Ansen Sprint's on 31x10.5" BFG Rugged Trails-Summer | | Stock Wheels on 30x9.5" AT's -Winter | | Exhaust Clip | Cardomain | Dual Outlet Flowmaster Club- Super 44Dark Descendant Dirty Tees Quote:
#20 | ||
Universal Cereal Bus
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
#21 | |
That or Im a complete r tard and have been driving it incorrectly for 6 years. In which case I better figure something out.
#22 | ||
and i can get to the speed limiter no problem in 4th....it takes a little longer than getting to 100 tho...but, thats because of the great aerodynamics ![]()
#23 |
Running 235/70/15's...My jeep hauls majorly on the lowend off the line. Minus roasting the tires (i need stickies, but i'm afraid the D35 will snap like a toothpick)
Anyways, after about 65, the Renix motor just has no more pep. Of course I am stock for now as well. Running the slightly lower tires definitely helps a ton off the line though.
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2 Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors Suspension: Gabriel VST Shocks Tires: Firestone "Firehawk Indy 500" 235/70/15's |
#24 | |
#25 |
Yea, you probably have more traction issues then me with that stroker.
I'm running a stock 2wd 88' renix 4.0 comanche, but the thing is, I've got no traction due to the light back end of the comanche, and the lowend torque from the renix. Besides, it's pretty barebone itself, i'd be surprised if it weighed in over 3,000lbs w/o me in it.
#26 | ||
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MTT%2D3055&N=700+ 4294923107+4294922134+400206+115&autoview=sku
#27 | ||
#28 | |
#29 | ||
#30 | |
and worcester is the greatest place ever lol i used to live there blood for blood owns
1991 XJ 4.5'' RE Super-Flex 31'' M/Ts on Cragar soft 8s..tons of other mods 1979 Pontiac Trans Am 1979 Monte Carlo 1974 Camaro worked 350, TH350 finished Summer 08...new obsession 2003 TJ 5spd...the new DD |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
