| #1 | |||
Registered User Join Date: Jan 2008 Location: Plattsburgh NY Posts: 10 | quest to 14's
| #2 | |
Registered User Join Date: May 2008 Location: United States Posts: 47 | I think the most you could pick up with bolton is 240 or so, see where that takes you I guess. |
| #3 | |
Banned Join Date: Feb 2005 Location: J-Ville,FL Posts: 2,361 | with full boltons (along with a junkyard gear setup) you should manage 14's with decent traction. |
| #4 | |
Registered User Join Date: Jan 2008 Location: Plattsburgh NY Posts: 10 | Well the easiest way would be nitrous but if i can get by with a cam and bolt ons then ill do that. i have never had a 4.0 apart but it is an OHC style engine? im probably going to pop the valve cover off and see what it looks like. |
| #5 | |
Registered User Join Date: Jan 2007 Location: Veneta OR Posts: 426 | no it is not an ohc style engine you can clearly see that just by looking at it the cam is in the bottom.... now these engines are pretty tough so...if you are only care about getting into the 14's I say nitrous is a a pretty good choice it's just you won't have the power all the time. Which is not a bad thing your mpg won't suffer unless you use it..... just my opinion though I would toss some shorter gears under it, do a stroker, get some sticky tires and be done with the 14's of course that would be a little bit more than you are probably looking to spend. but it would be well worth it __________________ 90' XJ 2dr 2wd Curent issues: OMFG you don't even want to know |
| #6 | |
Registered User Join Date: Jan 2008 Location: Plattsburgh NY Posts: 10 | well i dont want to build up the motor and you cant always tell a motor is or is not an ohc style by looking at it... but ill have to look up a diagram so i know what im looking at. ill probably end up using nitrous... what kind of kits do most 4.0 guys use? ZEX? if i can find a used kit, thats probably the route ill go. |
| #7 | |
Banned Join Date: Feb 2005 Location: J-Ville,FL Posts: 2,361 | well, the main giveaway for an OHC motor is the valve cover....if it doesnt look like it could fit a cam gear, then its not an OHC... You could really use any kind of kit depending on how "smart" you want the kit to be...N.O.S. has alot of accessories and a pretty decent reputation..(and its the system i used on my 90'XJ) |
| #8 | |
Registered User Join Date: Aug 2005 Location: kent county/eastern shore maryland Posts: 989 | i'd say easiest way would be to do a full exhust system a good intake system, nice tires and a good shot of nitrous. also i'd get good spark plugs and everything to support the nitrous system. the 4.0 is pretty strong and ca take some abuse but like any stock engine if you run a 250 shot though it you'll blow that thing up lol. __________________ 1996 jeep cherokee se 2 door 5 inch lift rear ended= totaled Rocky Mountain Edition Club member #4 project vehicle new 2002 jetta 1.8t DD |
| #9 | |
Registered User | I have a buddy that has a 92 2D XJ that runs 11.8 and 116MPH with a 200 shot on a v8 with 5in lift and 31in tires. There is a video of his run. But now that motor is in a 87 rx7 and that run a 11.1 on motor and a 10.7 on spray http://videos.streetfire.net/video/Fast-Jeep-Cherokee-Ran_132254.htm |
| #10 | |
Registered User Join Date: Jan 2008 Location: South Florida Posts: 418 | Found this video. I'm still trying to find more info on it.. Beating up a Subaru.. http://www.youtube.com/watch?v=KeWP5ElrGM8&feature=related |
| #11 | |
Registered User | My friend WJ with the 4L and a 90 shot ran a 14.76 in the 1/4. His had a exhaust W/cutout, ported TB and a B&G tuned PCM and intake. |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Garmin Quest 2 in a Trail Guide Mount | HoustonTJ | Electrical, Audio, & 2-Way Radio | 2 | 03-20-2009 03:52 PM |
| 9 inch quest. | tjbrotha | Engines & Drivetrain | 2 | 03-15-2008 09:57 AM |
| What will it take to get a 4.0L XJ in the mid 14's? | atmos_sc | Street Jeep Forum | 57 | 02-16-2007 08:59 PM |
| new procomp blue top - quest about cable replacement | snakehunter | Electrical, Audio, & 2-Way Radio | 6 | 08-14-2006 02:47 PM |
| CB install - wiring quest | kcphilaflyer | Electrical, Audio, & 2-Way Radio | 5 | 08-01-2005 05:55 AM |
Previous Thread
Next Thread
