pumping the gas and a bad fuel sensor - JeepForum.com
post #1 of 1 Old 12-28-2011, 07:44 PM Thread Starter
grfxfreak
First post -- hope you can help.
I have an 89 Wrangler that I am finally starting to fix up. One issue is that I have to pump the gas pedal 15-20 times to get it to turn over. I don't use it every day, but I wonder if there is an issue with the fuel pump or vacuum line that would require me to manually feed the carburetor.
Once it starts it runs fine.
On a related topic, my gas gauge never worked right and likely needs a new fuel sending unit -- I may as well try to fix all of it at once, but a bit green -- any info would be appreciated.
Thanks.
grfxfreak is offline
fuel gauge , fuel pump , newbie
'90 XJ Running issues TPS? MAP? Knock sensor? Fuel delivery? tommy-xj Engines & Drivetrain 7 10-03-2010 12:46 AM
ViAir pumping slowly chadsmeltzer General Jeep & Off-Road Equipment 14 11-16-2009 02:06 PM
fuel pump runs but not gettin any fuel chall08 Engines & Drivetrain 2 01-26-2009 06:04 PM
Fuel pump to fuel line fittings andynotandy Engines & Drivetrain 1 11-01-2008 09:56 PM
What Fuel Pump do I need for RCI Fuel Cell?? HootenTJ General Jeep & Off-Road Equipment 1 10-02-2006 01:55 PM
