Procedure for putting in/taking out TB? - JeepForum.com
post #1 of 4 Old 01-12-2008, 11:12 AM Thread Starter
Jeff9
Is there a procedure written anywhere that involves taking out and replacing the throttle body? In particular, the messing with the sensors scare me. I want to get a 63mm bored one but before I do so, I'd like to know exactly whats involved.
Thanks,
Jeff
Jeff9 is offline
post #2 of 4 Old 01-12-2008, 11:28 AM
sharktooth
Thanks,
Jeff
I don't know the procedure, but a Chiltons manual should tell you. I'm not even sure of what you are working with (e.g. a 1998 4.0l, a 1990 2.5l, etc). Odds are, you will get the best instructions from the manual. (I've only put on a TB as mine didn't have fuel injection to begin with.)
Joe
sharktooth is offline
post #3 of 4 Old 01-12-2008, 03:52 PM
Oizarod115
On a renix engine it's easy peasy... Just undo the 3 torx that hold the air intake tube on, the two torx that hold the IAC in (round thing on the side), unplug the TPS and then remove the 3 larger torx that hold the TB on (they're on the top of it once you undo the intake tube).
Unless I'm forgetting anything.
89 MJ - Stock but for the mods.
94 Dodge CTD and 16' flat deck
Oizarod115 is offline
post #4 of 4 Old 01-12-2008, 04:34 PM
SilverXJ
Knowing your year and engine would help.
But its easy. This is for the 4.0 HO, non renix
1) Remove air intake hose from TB
2) remove 1-3 cables from TB
3) remove plugs for sensors
4) remove 4 bolts securing the TB to the intake manifold
5) transfer old sensors to new TB using a torx screw driver
6) install TB with a new gasket and reverse steps 4-1
SilverXJ is offline
Radiator Replacement Procedure on my 93 XJ shelbydodge Engines & Drivetrain 1 04-15-2009 09:48 PM
Painting Procedure kirkhbauer General Jeep & Off-Road Equipment 13 02-26-2008 10:13 PM
new gear break in procedure question EMT Engines & Drivetrain 2 09-16-2006 07:57 PM
Post winch-dunking procedure MuddyV8YJ General Jeep & Off-Road Equipment 4 04-14-2004 03:49 PM
New 258' Break in procedure, help? mde Engines & Drivetrain 3 12-21-2003 10:46 PM
