Need help enclosed trailer lifted jeeps? - JeepForum.com
post #1 of 5 Old 01-24-2011, 11:08 AM Thread Starter
cescj85
I'm having trouble finding an enclosed trailer to fit my needs... Does anyone know a company that makes an enclosed gooseneck trailer over 30ft long and 7ft tall...? I've found trailers long enough and tall enough but for some reason I can't find both together in one trailer... I'm looking to haul a 04 rubicon w a 4in lift and a Cj-7 with 4in lift both with 33's. Any help would be appreciated
Stop when it sounds expensive!
cescj85 is offline
post #2 of 5 Old 01-24-2011, 05:23 PM
HotStuff
You'll just need to look harder. Sprint car trailers are usually taller than a regular trailer. You may have to order it special, as it may not be a regular dealer stocked item. My buddy has a 48' enclosed tri axle gooseneck to haul his nostolgia funny car in, and it has the tall roof. It's like 10' tall inside. Not sure on the brand tho.
'96 XJ 6.5" lift, 33's, HP30, 8.8", 4.56's, 4wheel disc, spooled rear, locked front, SYE, skids, yada yada yada.'51 Willys CJ3A 32's, 5.38's, locked front & rear, small block, Muncie 4speed.'76 CJ5 - UNDER CONSTRUCTION - resto/mod
HotStuff is offline
post #3 of 5 Old 01-24-2011, 05:27 PM
AFRd_CJ5
1976 CJ5
Yep, keep looking. I believe 6'6" is the "standard" height for most, but a common upgrade is for the 1 foot (which I believe is actually 7'7") higher ceiling. A lot of the trailers we looked at had that option.
AFRd_CJ5 is offline
post #4 of 5 Old 01-25-2011, 03:53 PM
Tolcar
I just typed in 'enclosed gooseneck trailers' in Yahoo and found this link.
http://www.missourigreatdane.com/wcgooseneck.htm
Click on the brouchure and spec's link and a .PDF shows what they offer.
Hope this helps.
Tolcar is offline
post #5 of 5 Old 03-02-2011, 05:06 PM
baritone_mike
If you would not be towing them around on a regular baises, you could put the windshild down and take the roll off. Or if you are close on hieght you could air down (with the CJ you have 9 inches of rubber below the rims so you could easily get rid of 4-5 inches of hight with out damaging anything.
You could also find 2 sets of small tires (like they do for monster trucks) which might be cheaper then the extra foot of trailer hieght.
baritone_mike is offline
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 06:43 PM
Building Box for Enclosed Sub and Amp, Suggestions? harleysilo Audio, CB & Ham Radios, GPS, & Electrical 4 06-15-2009 07:58 AM
Why Do Lifted Jeeps Sag to One Side? ADay73 Tires & Wheels 4 08-14-2007 11:03 AM
anyone tow a Motorcycle enclosed trailer with their TJ or LJ??? rockhi General Jeep & Off-Road Equipment 4 05-09-2007 05:19 PM
Kenwood Powered enclosed subwoofer JPLIVE Audio, CB & Ham Radios, GPS, & Electrical 10 07-22-2005 04:55 PM
