n20jeep - I think you have some competition in the NOS department - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > n20jeep - I think you have some competition in the NOS department
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 11-12-2007, 03:13 PM   #16
urban-yan
Agreed, he needs more, and the kit isn't concealed (check the link).
Maybe he uses a small shot because:
01) the jeep is a daily driver
02) he's trigger happy
03) he has 169k miles on the truck
04) he's a p*ssy lol
urban-yan is offline   Reply With Quote
Unread 11-12-2007, 05:00 PM   #17
red96jeep
i go with number 4, juice it up more!!!
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline   Reply With Quote
Unread 11-12-2007, 05:13 PM   #18
n20jeep
1993 XJ Cherokee
someone should invite him here to the street jeep section
n20jeep is offline   Reply With Quote
Unread 11-12-2007, 07:49 PM   #19
alexrule123
Wishes he had a frame
alexrule123's Avatar
Originally Posted by gregmondro
Yeah, but if/when you break an axle, yours will walk right out of the tube while his wont.
The day I make enough power to break an 8.25 axle shaft I won't care if it walks out of the tube.
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, IRO 5.5" Leaf Springs, Liquid Iron Industries Slider Boxes, 35x12.50 Goodyear MTR/K, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, WJ Brakes and steering, JCR Rock Sliders, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
May 2013 COTM
alexrule123 is online now   Reply With Quote
Unread 11-12-2007, 08:02 PM   #20
urban-yan
I can't invite him here... especially after calling him a pu$$y in post 16
Unread 11-12-2007, 09:22 PM   #21
alexrule123
invite him...you won't...I dare you!!
May 2013 COTM
Unread 11-14-2007, 09:15 PM   #22
XJ4oh
1997 XJ Cherokee
Dont think id spray a 169k tractor motor anymore than a 50-75 wet shot even if I felt lucky.
What kind of kit is he using?
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
XJ4oh is offline   Reply With Quote
Unread 11-16-2007, 01:47 PM   #23
fitbmxseries1
1987 YJ Wrangler
it is good to know you can spray it with 165 k miles. Should there be some kind of fuel system upgrade? you can you just slap a wet kit on and be fine?
fitbmxseries1 is offline   Reply With Quote
Unread 11-16-2007, 04:38 PM   #24
n20jeep
1993 XJ Cherokee
depends how much of a shot you want
Unread 11-22-2007, 09:04 AM   #25
fitbmxseries1
1987 YJ Wrangler
how much of a shot before you would have to start upgrading?
Unread 11-22-2007, 12:02 PM   #26
SoloCamo
1988 MJ Comanche
Anything above a 25 shot more than likely. Even 25 probably runs the risk of running slightly lean on stock injectors as well.
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline   Reply With Quote
Unread 11-23-2007, 04:35 AM   #27
n20jeep
1993 XJ Cherokee
50 would be fine
Unread 11-23-2007, 07:50 AM   #28
ultradriver1000
why can't you run more of a shot will the fuel pump not handle it?
A wet shot adds in fuel along with nos, so unless the fuel pump can not keep up it should be fine....
I run a 150 wet shot on my stock ls1 in my summer car....I think a 75 shot wet would be fine on the 4.0l
ultradriver1000 is offline   Reply With Quote
Unread 11-24-2007, 10:17 PM   #29
SoloCamo
1988 MJ Comanche
50 would be fine
On stock fuel? Wouldn't it run lean at the higher rpms?
Unread 11-25-2007, 01:17 AM   #30
Drparj
The design of a wet system to dry
Dry is just NOS going into throttle body
Wet is more plumbing as it has a NOS going in and a seperate fuel line going in thus the wet part. It keeps injectors stock and adds NOS and fuel byitself. Good for alot of vehicles that don't have heavy mods so no need to get bigger injectors of fuel pump. Most any fuel injected car's pump can handle it due to its high volume design. But any vehicle over 100k you are pushing your luck with more then 50 shot as rings and seal might be able to handle the pressure so late in its life. I have 116k on mine and I want a 75 shot. I am trigger happy so I don't want to kill the engine sooner then wanted. I will start with a 25shot for a few weeks then 50, then 75. This should help the rings and seals get use to higher pressure and not all at once.
2001 Grand Cherokee Limited
Drparj is offline   Reply With Quote
