My Wrangler Hot Rod - Page 4 - JeepForum.com
 1Likes
post #46 of 124 Old 08-23-2011, 04:36 PM
kyle1922
Dont know if any one has seen this but its fin crazy. Typical germans.....
http://www.streetfire.net/video/jeep...ile_189278.htm
and one of it on the dyno.
http://www.streetfire.net/video/jeep...4hp_687094.htm
kyle1922 is offline
post #47 of 124 Old 09-26-2011, 11:36 AM
TxJeeper20
1982 CJ5
If it would have keptthe 4wd and not lowered so much It would be a super jeep Drag it on the weekends take to work during the week and dirt roads on friday night lol awsome build
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #48 of 124 Old 01-28-2012, 05:36 PM Thread Starter
Lee3333
I humbly apologize for not updating things for so long, but I have been very busy with my wife, kids, house projects, and of course working on my Jeep. But a lot, and I mean a lot, of things have been done since I last posted. (By the way, I also apologize for not responding to any posts on this thread, but I do not get notifications on activity so I do not know when people are posting here. Yes, I was at the Maspeth Bank car show and yes, that was Atco.
Anyhow, my Jeep has been undergoing a lot of changes. First, I designed a new top for it. I was not happy with the factory design, taking 45 minutes to put up or take down, and I thought it looked ugly wrapped around the tub all spring and summer long. So I got a top from Rampage-it was very cheap because it was returned to them as defective (a zipper was busted). It was originally designed for the soft doors. I made a surround bracket by bending a threaded rod to the same contour as the full steel door, then attached it using the Bestop lower bracket and 2 hose clamps to attach the top to the roll bar. (I covered it with a piece of rubber hose.) I used the Bestop bows, but modified the brackets and installed a short piece of cable between them so that when the front bow is pulled forward and resting on the roll bar, the rear bow is held up in the proper position to keep the top at the right height over the back seat by the cable. I took it to a local custom top/upholstery shop-McCoys. I worked with one of the fabricators altering it for 2 days, and came up with a top that comes completely off in under 8 minutes and neatly folds up and is stored in a bag that fits in a compartment behind the back seat. (I use snaps I installed around the tub for my cab cover. I needed them to secure the cover since I no longer have the lantern lights or spare tire that it normally is tied to.)
Next, I had to work on the engine. When we tried to adjust the valves, they were loose and some of the springs were very weak (one you could actually compress with your fingers). We installed an Edelbrock top end kit, with Vortec heads and a roller cam (and retrofit kit). We also replaced the noisy timing gears with a double roller chain, a new Melling oil pump and deep sump oil pan, and an aluminum Edelbrock water pump. [Installing them we discovered that the block was not the 4 bolt main .030 over engine I thought it was. So in the spring I plan on doing the bottom end.] We also replaced the fuel line with 1/2 inch stainless steel, cleaned up the engine compartment and put aluminum on the firewall, and rewired the entire car. The front fenders were rusty so we replaced them, and painted the whole car. We made a custom grill to keep leaves and stuff from clogging the radiator. And, best of all, we redid the exhaust using stainless steel, Magnaflow mufflers and electric cutouts.
Right now I am in the midst of installing new black door handles and making new door panels. I just finished one side and have to do the other side now.
Performance wise, it is naturally much faster. Before I did 0 to 60 in 4.5 seconds, and now I can do it in under 3.8. That should put me into the 11's. And who knows after the rest of the engine is done.
Lee3333 is offline
post #49 of 124 Old 03-06-2012, 10:08 AM
castorriver
Who says a Wrangler ain't fast.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #50 of 124 Old 03-07-2012, 06:35 PM
pasinbuy
Looks good. Thanks for the update.
pasinbuy is offline
post #51 of 124 Old 03-07-2012, 10:04 PM
straightsixjeep
Drag Jeep, love it! Get a video if you have a chance.
straightsixjeep is offline
post #52 of 124 Old 03-11-2012, 08:51 PM
clinton2292
did you make it in to the 11s
clinton2292 is offline
post #53 of 124 Old 03-15-2012, 05:44 AM Thread Starter
Lee3333
Haven't been to the track since I replaced the old damaged heads (and new cam, etc). But the 0 - 60 time dropped from 4.5 to 3.8 seconds, so it is much quicker. And I just ordered a new short block (discovered mine was stock, not performance like I thought). It will be 383 with forged crank and 10.25 pistons. Ran consistant 13.1's before, so should be in deep 12's or high 11's now.
Saw you posted on the Drag Times. Looking forward to some photos.
Lee3333 is offline
post #54 of 124 Old 03-20-2012, 09:34 PM
clinton2292
Its at the roll cage shop right now they have had it for 2 weeks
post #55 of 124 Old 03-21-2012, 07:36 AM Thread Starter
Lee3333
What are they, bending the tube with their teeth? Hopefully it will be done soon. Have you seen AFRd_CJ5's Jeep yet?
Maybe we are starting a trend with Hot Rod Jeeps! Yesterday I picked up my daughter from school and took her for pizza in my Jeep. She wants to be a famous pop singer, and said driving in the Jeep is good practice since people keep coming up to you (At least 10 people stopped me to talk, took pictures, gave thumbs up, etc in the 15 minute drive.)
Wait till you see the new custom plate I ordered.
Lee3333 is offline
post #56 of 124 Old 05-04-2012, 05:04 PM
TexasPigHunter
You have the same idea and thoughts that I have. I'm wanting another YJ, but this time something fast. I have been thinking about using the drive train from a '04 Chevy SS truck, it's got the 6.0 and all time all wheel drive. If I could squeeze that into the YJ that would make for one heck of a street/strip Jeep. But that's a few years in the making
TexasPigHunter is offline
post #57 of 124 Old 05-04-2012, 05:27 PM Thread Starter
Lee3333
There's no reason you couldn't make it all fit.
Here is picture of my new plate
Lee3333 is offline
post #58 of 124 Old 05-04-2012, 09:03 PM Thread Starter
Lee3333
JP magazine should love that plate. I just sent them a picture of it.
Lee3333 is offline
post #59 of 124 Old 05-08-2012, 08:03 PM
tjindiana
2015 JK Wrangler
Nice Jeep. Do u know the parts number on your upper and lower hoses for the radiator?
Might save me hours at the parts store.
2015 JKU Sport White, 3.73 gears, 285/75/16
tjindiana is offline
post #60 of 124 Old 05-09-2012, 07:22 AM Thread Starter
Lee3333
Hoses are upper GTR-60866 Lower GTR-60709 (Goodyear)
Both require cutting off some of the ends. Keep in mind that I used a Griffin radiator. Other ones may have different locations for the hoses.
Lee3333 is offline
Will a 2.5L out of a 95 wrangler work in a 98 Wrangler? msbjeep Engines & Drivetrain 2 10-07-2009 06:40 PM
Adapter for 2008 Wrangler Wheels to fit a 1999 Wrangler BrentwoodUPSER Tires & Wheels 9 03-12-2009 07:21 PM
2003 Wrangler stereo removal similar to 1999 Wrangler? 0okamiDigital Audio, CB & Ham Radios, GPS, & Electrical 2 02-24-2009 08:03 AM
Will a 03 Mopar Wrangler Hard TOP fit an O6 Wrangler? CAS300D General Jeep & Off-Road Equipment 1 09-08-2008 11:49 AM
wrangler mt/r's jfondren3 Tires & Wheels 5 01-29-2007 11:15 PM
