06-04-2006, 06:21 PM
#1
Resident Audio Guru
So im going to be boring out my TB next weekend, and getting a cone air filter for my 4.0.
In order to let it breath a little more, im also looking into headers.
http://www.autopn.com/store/pc/viewp...dProduct=20009
This part is listed as a manifold for the 4.0. What is the difference between a header and a manifold? Does that 'manifold' in the link flow any more than the stock one?
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
06-04-2006, 06:22 PM
#2
Headers flow a tad bit more mainly because of their lenght, but that's a well designed exhaust manifold so it would be close. I've heard on the 4.0 it's not that much of a gain over the stock exhaust manifold. I have the stock manifold wrapped in header wrap, flows great and works fine for me.
06-04-2006, 06:23 PM
#3
Resident Audio Guru
Do you have any engine/exhaust mods? like bored tb, high flow cat/muffler, or cone filter?
-Matt
White '94 YJ Sport
06-04-2006, 09:09 PM
#5
Resident Audio Guru
Haha, didnt realize who you were  thanks for the info
-Matt
White '94 YJ Sport
06-04-2006, 09:43 PM
#6
4.0's come stock with a header. Thats why there isnt a huge gain in stepping up to a performance header. You can improve with a good header and new downpipe from what I hear.
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
06-04-2006, 10:45 PM
#7
Huh? No they didn't. What cam stock is a manifold, not even close to being a header...
06-04-2006, 10:55 PM
#8
Nevermind, its late and im not thinking right.
Baja Aux. Lighting.
06-05-2006, 01:22 PM
#9
I thought they were different names for the same part. They serve the same purpose and are installed in the same location. Exhaust manifold is usually in reference to the stock peice and header is usually the term for the aftermarket peices that will flow more.
88 Cherokee. 300,000 miles!
03 Mustang Cobra. 450 RWHP
06-05-2006, 01:41 PM
#10
A header has equal length tubes that flow into a collector, a manifold has neither of these.
As you can see...
Stock:
Header:
Notice the equal length tubes and collectors at the ends on the header. The stock one dosn't have either of these features.
EDIT: For some reason pics didn't show up, they are links. Sorry about that, not sure why that was the case.
06-05-2006, 03:55 PM
#11
As you can see...
Stock:
Header:
There are equal and unequal length headers therefore your definition is incorrect.
06-05-2006, 03:58 PM
#12
www.lp.org
I replaced the cracked, stock mani with a Gibson stainless. I noticed a nice gain in power. The stock manifold isn't designed to flow or to time exhaust pulses. The pulse timing is what is important in header design. If you're looking for gains, I'd get a Banks or Gibson. Basically, buy something that is marketed as a "header".
Derpy Hooves for President in 2012
06-06-2006, 02:48 PM
#13
I've always thought the diference was that exhaust manifolds were a cast piece, and the tubular pieces were headers (whether stock or not).
94' XJ - 3"lift, 31s
06-06-2006, 03:54 PM
#14
If I am not mistaken a header IS technically an exhaust manifold, the correct nomenclature is: performance tuned equal length tubular exhaust manifold, whereas the factory item is simply a tubular exhaust manifold. Are they both headers...well depends on who you ask. 'Header' used to be reserved for tubular exhaust manifolds which were only found on high end exotics, tuners, etc., but since most modern cars now come with some sort of tubular ex. manifold, as opposed to the old heavy cast iron units, often people refer to any aftermarket exhaust manifold as a header whether it be of equal length or not.
XJguy
06-07-2006, 02:43 PM
#15
www.lp.org
They don't need to have equal length primaries. Show me an equal length header for a 4.0. They're rare, because they would mis-time the exhaust pulses. You need to have unequal primaries in order to properly sync the pulses for maximum scavenging.
