lowering my 96 xj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > lowering my 96 xj
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-03-2008, 08:36 AM   #1
skyjacked94xj
lowering my 96 xj ---PICS!----
Ok, my *** end is sagging pretty bad, so I decided i want to lower the front alittle to match the back. If I pick up some stock xj coils from the junkyard, can't I just hack off one ring of the coil? The front only needs to come down about an inch or so.
Is there anything I have to watch for with the sagging leafs??
How about shocks? I'm sure I can run the stocks without a problem..
I can see it now, lowered alittle bit with some 255's on my icons..
Edit, I just lowered it, tell me what you think/...
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline   Reply With Quote
Unread 04-03-2008, 11:29 AM   #2
seanyb505
1997 XJ Cherokee
My rear leaves are sagging bad and I did the same thing you are thinking about. Results:
Now with 16s, which will be wearing 255/55/16 when the Goodyears wear out. The 225s on now are 29" tall, and the 255s will be 27", so it will be another 2" inches lower. Freakin cant wait!
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
www.jeepstrokers.com
seanyb505 is offline   Reply With Quote
Unread 04-03-2008, 05:34 PM   #3
skyjacked94xj
so did you just cut off one section of the coil spring?? That thing looks pretty nice, i like the stance..
DAILY DRIVER
CLASSIC TOY
Project
Unread 04-03-2008, 06:27 PM   #4
UltimatE
Resident Audio Guru
UltimatE's Avatar
1" lower from the tires.
And I too have cut the front springs. Cut exactly 1 ring off, and it sits nice and level. Been running this way for a year now.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 04-03-2008, 06:51 PM   #5
skyjacked94xj
Lets see that set-up too... if you have any pictures...
DAILY DRIVER
CLASSIC TOY
Project
Unread 04-03-2008, 09:26 PM   #6
UltimatE
Resident Audio Guru
UltimatE's Avatar
Before:
After:
-Matt
White '94 YJ Sport
Unread 04-04-2008, 12:24 PM   #7
seanyb505
1997 XJ Cherokee
Nice color! I just found the end of the spring, and went straight up from there to cut. You might have to get it aligned afterward.
Unread 04-04-2008, 03:49 PM   #8
skyjacked94xj
nice, that looks alot better, now all you need is some different wheels.....
DAILY DRIVER
CLASSIC TOY
Project
Unread 04-05-2008, 01:48 PM   #9
skyjacked94xj
bump, tell me what you think... Its done. Exactly 30" in the front and rear.
DAILY DRIVER
CLASSIC TOY
Project
Unread 04-05-2008, 07:37 PM   #10
SilverXJ
30"? 30 what?
I guess this is one way to make a bad situation(sagging rear) better. What about TJ coils? I have heard tha they will give your less height. Also, one other thing you have to take into consideration is the axle centering and caster (if it is changed that much at all).
SilverXJ is offline   Reply With Quote
Unread 04-05-2008, 08:28 PM   #11
seanyb505
1997 XJ Cherokee
I actually got lucky with my alignment. I needed it before I lowered it, and when I did it fixed the problem, that is a nice looking job btw! Looks very sporty.
Unread 04-05-2008, 08:41 PM   #12
88XJSport
1988 XJ Cherokee
I really like it!! Looks good!
88XJSport is offline   Reply With Quote
Unread 04-05-2008, 09:52 PM   #13
skyjacked94xj
Originally Posted by SilverXJ View Post
30"? 30 what?
30" from the ground to the bottom of the flares...
DAILY DRIVER
CLASSIC TOY
Project
Unread 04-06-2008, 05:37 AM   #14
SilverXJ
The measurements are taken from the bottom of the flare to the center of the hub. Stock would be 17.5" front and 17" rear.
Unread 04-06-2008, 11:17 AM   #15
skyjacked94xj
Yeah I know that, I'll take measurements from the area too, should end up being the same..
DAILY DRIVER
CLASSIC TOY
Project
