keyless entry probs - JeepForum.com
post #1 of 5 Old 05-11-2013, 08:29 PM Thread Starter
00grdcherokee
keyless entry probs
I have a 2000 jeep grand Cherokee and i purchased it used and it did not have a keyless entry remote, so i purchased one used off of ebay and it is the correct model, i programmed it into the above console and it reads transmitted but the buttons on my remote will not unlock/lock/panic. The batteries work and are in correctly. What do i do?
00grdcherokee is offline
post #2 of 5 Old 05-13-2013, 09:34 AM
Indy
Indy's Avatar
Your best bang for the buck in my experience, go aftermarket. Mne with new batteries has a range of about 4 feet on a good day. Most times its inches, like pretty much touch the door handle with the remote o make it work. Easier to use the key. Unfortunately, thats not unique, the keyless just sucks on these things.
http://www.thejeep.com/program.html
I'm the only gay eskimo.
Indy is offline
post #3 of 5 Old 05-18-2014, 07:38 PM
TurnerBurner
Check the keyless module in the passenger door, from what I've read here this is where my issue is.
TurnerBurner is offline
post #4 of 5 Old 05-24-2014, 06:46 AM
Dealwitit
You said you bought it used, there's your problem if u can don't ever but used electronics that dude u got it from sold u junk. I have a 2000 wrangler i bought a Markman in 03 haven't had any issues with it I can have it start up every half hour in the snow to keep the block warm every hour for 15 minutes starts up by itself. Wish you luck.!!
Dealwitit is offline
post #5 of 5 Old 05-25-2014, 02:51 PM
narnwv
narnwv's Avatar
The EVIC (over head console) that will give you the "transmitted" message is for garage door openers.
To have the remote programmed, you HAVE to go to the dealer. (or know someone with a DRB III Chrysler Scan tool)
~Aaron
narnwv is offline
