Installing Subs, where to drill for power cable? - Page 2 - JeepForum.com
post #16 of 20 Old 11-08-2012, 08:11 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Don't know if you have it, but...lift the hood, passenger side, at the back of the valve cover where the firewall has a lg contour to accomidate the long I6 block, there's a grommet I was able to feed a O awg cable through.
D3<!L!>3D
S8NNG8 is offline
post #17 of 20 Old 11-08-2012, 08:14 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
And use the seat belt mounts under the back seat, you want your grounds to be as short as possible.
D3<!L!>3D
S8NNG8 is offline
post #18 of 20 Old 01-24-2013, 02:44 AM
xrunndonex
1994 ZJ
Yea it's a decent ground but better is throwing amp on floor and drilling through floor and still into the frame.
xrunndonex is offline
post #19 of 20 Old 01-24-2013, 02:48 AM
xrunndonex
1994 ZJ
Originally Posted by Jeepster2k3 View Post
blue/white for the amp switch. Or you will endup like i did and only have the amp on when you are using the radio (blue is power antenna so its off when on aux)
Or if you wanna be a rebel attach remote to ignition :P
post #20 of 20 Old 08-28-2013, 06:00 PM
WJefy
I know this thread is a little old now, but here's the easiest way to put power through a firewall...
Buy (or pilfer) a full length, non-collapsing antenna from some old car in a junk yard. Use a grinder to sharpen one end to a point. Cut your power wire at an angle and tape it to the non-sharpened end of the antenna. Make sure you run the tape up the antenna past the point of the power wire. Coat the tapered area with some kind of lube. Soap water, white lithium grease, professional electricians' lube, etc. poke the pointy end of the antenna through an existing grommet on the driver's side of the engine compartment, slide it down until the lube is on the grommet, go back and forth a couple times, then pull the antenna through from the footwell. It has worked for me on EVERY vehicle for more than 300 amplifier installs. No drilling necessary. The grommet seals around the wire on its own. Drilling complicates things very quickly. I've heard horror stories of drilling into ac lines, through the back of the master cylinder (without noticing until the customer's car could stop - yikes), and others. Again, no need to drill.
WJefy is offline
subs and metal cable, will it mess up the magnets in the subs wakeboarder 21 Audio, CB & Ham Radios, GPS, & Electrical 8 07-12-2010 05:22 AM
installing 3 subs and amp in liberty Mike1127 Audio, CB & Ham Radios, GPS, & Electrical 18 06-16-2010 11:55 AM
installing subs and amp in a wrangler platinumjeep Audio, CB & Ham Radios, GPS, & Electrical 4 01-17-2009 11:01 PM
Need the PERFECT amp to power dual 8" subs. Mr_McNasty Audio, CB & Ham Radios, GPS, & Electrical 6 06-19-2008 05:32 PM
loss of some power to subs Slippy Audio, CB & Ham Radios, GPS, & Electrical 14 04-24-2006 11:02 AM
