I wish to convert my 5.9 grand cherokee to a street jeep....sugjestions? - JeepForum.com
post #1 of 11 Old 08-01-2012, 04:18 AM Thread Starter
scottys94XJ
i have a 1998 grand cherokee 5.9 limeted....xj is gone.....soo i want to build a street jeep...i need supreem handleing...i alredy know what i need for motor and trany....i need to be lower and sifer terning....also is it posible to get rid of the front diferental and have just a normol axle like on a 2 wheel drive...and is it posible to remove front gear box and have just a straight drive shat 2 the back....just to wheel drive and a lot less waight...let me know whats up !
scottys94XJ is offline
post #2 of 11 Old 08-10-2012, 09:10 AM
Dusk53
Just curious as what you're plans are. 408 stroker?
Traction will be an issue, why do you not want 4wd? Assuming we're talking for a drag strip here.
Mah build
East Carolina University
Dusk53 is offline
post #3 of 11 Old 08-10-2012, 01:34 PM Thread Starter
scottys94XJ
i did moar reserch and watchd alot of videos....i want it to be a street jeep
lowerd re-geard wider tb ported intake stif suspention ect...im open to everybodys segjestions
post #4 of 11 Old 08-25-2012, 07:47 PM
redef9sir
Currently working on a project similar to the one you are interested in except mine is using a 1982 full size Cherokee chief as a platform. I already sourced a new front independent suspension from a late model crown Vic which has killer brakes on it with rack and pinion steering and should lower the truck 5 inches. Obviously that will eliminate the solid front axle along with the steering box. The th400 is getting replaced with a mustang t5 and the transfer case goes away too. Haven't decided how to handle the rear suspension yet but I think I will have to notch the frame eventually. Good luck
redef9sir is offline
post #5 of 11 Old 08-26-2012, 05:38 PM
rjbruzan
Start with a 2wd front axle and some lowering springs.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 11 Old 08-27-2012, 09:49 AM
bobjp
Why not just buy a 2WD Jeep to start with? You'll spend twice as much money converting it to 2wd then if you were to just buy a 2wd. A 5.9L 98 is worth decent money and you're just going to take the engine out anyway.
97 TJ sport.
bobjp is offline
post #7 of 11 Old 08-27-2012, 09:54 AM
HereticalWJ
His posts hurt my head to much to help.
HereticalWJ is offline
post #8 of 11 Old 09-01-2012, 12:32 AM
kingharrod83
I agree. Just leave that jeep alone. I have a 98 5.9L and it's pushing 480hp with a 5.9. Jeep is a collector and should stay almost stock
kingharrod83 is offline
post #9 of 11 Old 09-01-2012, 12:45 AM
360LJ
What do you have done to this 5.9? I am in for 480hp!!! What mods?
2007 JKUR with some stuff bolted on it and a hemi
360LJ is offline
post #10 of 11 Old 06-24-2013, 12:48 AM
jeffjeep2
98 zj for street
Hi everyone,
Need your advice Im planning to make my jeep a bit street jeep because I dont do 4 x 4 on the dessert mostly i used it for office.
Here is my plan to put in a 235x50x18 set of tires and rim, currently the jeep is in stock tires at 235 x75 x 15. jeep also never lifted. still stock. im planning on dropping it 2 inches down, im still searching for some good springs.
Thanks
jeff
jeffjeep2 is offline
post #11 of 11 Old 06-24-2013, 12:02 PM
rgreen
do tell your mods... i too have had (sad to say she isn't with us anymore) 5.9L GC and with the mods i did i was able to run a 13.7 and was nowhere near 480hp.
rgreen is offline
95 jeep grand cherokee 9jeepcherokee5 General Jeep & Off-Road Equipment 0 07-03-2012 04:48 AM
Jeep Grand Cherokee 5.9 acebailey Audio, CB & Ham Radios, GPS, & Electrical 2 05-08-2012 09:08 AM
Looking to buy Jeep Grand Cherokee txaggies08 Engines & Drivetrain 0 09-21-2011 01:22 PM
04 Jeep Grand Cherokee JeepGC121 Audio, CB & Ham Radios, GPS, & Electrical 0 07-09-2010 08:37 PM
Project Street Jeep Cherokee byron_nuffer Street Jeep Forum 21 12-09-2008 05:25 PM
