for the guys with lowered xj's - Page 3 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > for the guys with lowered xj's
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-11-2007, 11:04 PM   #31
seanyb505
1997 XJ Cherokee
I did it today, took me about an hour. It looks good but not like a horrible road scrapping crapper. I havent been able to test the limits, but it feels more capable.
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
www.jeepstrokers.com
seanyb505 is offline   Reply With Quote Quick reply to this message
Unread 05-28-2010, 12:45 PM   #32
rocksbite
you can go more then 2" in the front. the axle sitting on the bump stops is still 3 or 4 inches from the oilpan. i swapped in tj coils then cut out one coil from the bottom. cutting the coil out only changes the ride height not the spring rate. the only time i hit the bumps in the front is when i hit a hugh pot hole or rr tracks. as far as the rear i cut the lenght of the leafs down to match the next one..
92 wrangler, comp cut, flat fenders, 101" wb, np231/d300 dual cases, d44's, rear disc brakes, s10 blazer leafs, 36" goodyear military oz, BLUE JEEP CLUB MEMBER #157
rocksbite is offline   Reply With Quote Quick reply to this message
Unread 03-18-2012, 11:30 AM   #33
solidsnake1761
Ok so how much do you need to cut of the ford springs i think if you did a spring under on a Cherokee it would be to low and would need to buy lift springs
solidsnake1761 is offline   Reply With Quote Quick reply to this message
