for the guys with lowered xj's - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > for the guys with lowered xj's
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-12-2006, 09:17 PM   #16
Wazzuppiggy156
1995 XJ Cherokee
dude it's a jeep if you want somthing THAT low get an s-10 lol. if you do want it lower then yes put like an inch lift block in between the spring and axle, now come on was that to hard to think of?
God...Sorry. Wasn't trying to offend anyone
your profile says you have a D35 front....true?
Yessiree Bob...What about it?
Wazzuppiggy156 is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 12:48 AM   #17
UltimatE
Resident Audio Guru
UltimatE's Avatar
You shouldn't have to apologize for anything. This is the Street Jeep section for a reason. Supposed to be no hating here, or anywhere on this forum for that matter.
If its not your jeep, and you have nothing positive to say, shut your mouth.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 01:41 AM   #18
sharpie
go to driveautogear.com!
sharpie's Avatar
1999
what about it is that no XJ came with a front D35. Ever.
http://www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/
"Front Axles
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints - used 00-01"
and to be on topic, I have a 98 as well, and I believe mine is spring under as well. Maybe it was a 98 thing?
[SIGPIC][/SIGPIC]
Check out our shirts in the Vendor Display Forum!
- Brian
Drive Auto Gear
Drive Auto Gear Website
Like us on Facebook!
XJ Writeups:
| DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE
sharpie is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 08:09 AM   #19
Twsty
1988 MJ Comanche
i do believe that no XJs ever came from the factory w/ spring under.
1988 MJ 4.0/D60/14b/5.38/42s/PSC hydro
1995 XJ 4.0/AW4/231/JCR sliders/235s on KJ 16" wheels
1996 F350 PSD/ZF5, 375hp/692ftlbs
Twsty is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 01:23 PM   #20
UltimatE
Resident Audio Guru
UltimatE's Avatar
All XJ's are spring over. Every lift kit you see is for 84-01. If some were spring under, you would need a much taller spring for the rear.
-Matt
White '94 YJ Sport
Unread 11-13-2006, 01:31 PM   #21
Ivanito
Err mine too is a 98 and it is spring over. Care to take a picture of said axle?
Ivanito is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 08:11 PM   #22
Wazzuppiggy156
1995 XJ Cherokee
Oop Sorry! Guess maybe D30? I'll have to change that now... But mine is a 95 with a spring over, the again it IS used, maybe the guy before me lowed it...idk..
Yeah I'll try to get a picture, my crappy target camera dosn't like to work though...
Unread 11-13-2006, 08:19 PM   #23
XJ4oh
1997 XJ Cherokee
Comaches were leaf under axle, XJ's not.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline   Reply With Quote Quick reply to this message
Unread 11-13-2006, 08:23 PM   #24
Wazzuppiggy156
1995 XJ Cherokee
Like I said though...idk if mines just goofy or what...
Unread 11-14-2006, 04:55 PM   #25
red96jeep
yeah its goofy apprently lol.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline   Reply With Quote Quick reply to this message
Unread 01-20-2007, 01:00 PM   #26
RoundeyeXJ
Has anyone ever looked to see if an S-10 or other truck's drop spindle would work on on a 2wd xj/mj ? s10 brake upgrades would be nice too what about other handling upgrades? what else can I do to make this comanche handle better?
RoundeyeXJ is offline   Reply With Quote Quick reply to this message
Unread 01-20-2007, 02:37 PM   #27
Ivanito
Your best bet is larger swaybars. Im pretty sure the larger ones that work for the xj will also work for the mj.
Addco swaybar for sale
http://www.jeepforum.com/forum/showt...77#post4664677
Unread 01-20-2007, 11:40 PM   #28
KC Jr 54
Well i have been considering this myself and here are my thoughts for the rear.
Get a 8.8 out of a 95+ explorer.
Positives:
3.55 or 3.73 gear and it think i even heard about a 4.11 but i am not completely sure about that.
LSD is in some of the axles as well
Disc brakes.
MUCH stronger then the D35.
Cons:
I think it is narrower then the stock D35, but i heard it was only by 1.5"
I am not sure about the axle tube diameter on the 8.8 but briefly looking at whats in mine already i think you get get a 3.5" of drop just buy doing that, and if that is to low, which it would be if you want to level the jeep, i was thinking that maybe a set of shackles could temporarily solve the issue. Maybe a set of full packs, to lift it back up a little and give better geometry all around.
Again this is my understanding of it all and i could be pretty far off on it, so if i am please let me know and i promise i wont get mad
How does that sound to the rest of you guys ?
KC Jr 54 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 11:56 PM   #29
seanyb505
1997 XJ Cherokee
Im contemplating lowering the front to equal the sag in back. I dont want to butcher my jeep and screw something up, so I want to know exactly what im doing. When cutting, do you just measure from the lowest point to the desired level of drop? Or do you have to go straight up from where the spring material ends and cut one coil at a time?
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
www.jeepstrokers.com
seanyb505 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2007, 08:42 AM   #30
UltimatE
Resident Audio Guru
UltimatE's Avatar
When I lowered mine to match the rear sag I cut exactly one coil off and it worked out nicely.
Before:
After:
And the whole jeep after:
-Matt
White '94 YJ Sport
