for the guys with lowered xj's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > for the guys with lowered xj's
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 11-08-2006, 09:46 PM   #1
Isles96
Hey guys, I have a 98 sport and was wondering how you lowered your jeeps and how much it was lowered as a result. I am looking to do this in the near future and i'm trying to find the best way to go about it. Thanks in advance.
'98 Sport 4x4 4dr
4.0L Auto
Canyon Wheels 225/75/15
Isles96 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2006, 10:13 PM   #2
UltimatE
Resident Audio Guru
UltimatE's Avatar
F150 cut coils. Stiffer springs, better handling. Can't lower it more than ~2" or you'll play tag with your oil pan.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 11-08-2006, 10:28 PM   #3
Ivanito
tj springs for a stock ride but 1" lower
Ivanito is offline   Reply With Quote Quick reply to this message
Unread 11-09-2006, 04:37 PM   #4
Isles96
So cut F-150 coils for the front. What about the rear.
'98 Sport 4x4 4dr
4.0L Auto
Unread 11-09-2006, 05:23 PM   #5
95SQCherokee
1965-1979 Ford 3/4 ton Full size pick-up springs are the ones you want. Advance Auto Part part# CS8228.
http://www.partsamerica.com/ProductL...tnumber=CS8228
Take a music bath once or twice a week for a few seasons, and you will find that it is to the soul what the water bath is to the body.
Mark A. Brooks
Co-Owner and Founder
Audio By Design
Miami, FL
95SQCherokee is offline   Reply With Quote Quick reply to this message
Unread 11-11-2006, 01:16 PM   #6
Wazzuppiggy156
1995 XJ Cherokee
I am also Interested about the rear as well....how would one go about lowering it?
Wazzuppiggy156 is offline   Reply With Quote Quick reply to this message
Unread 11-11-2006, 01:21 PM   #7
red96jeep
do an axle over spring.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline   Reply With Quote Quick reply to this message
Unread 11-11-2006, 01:25 PM   #8
Wazzuppiggy156
1995 XJ Cherokee
Mine is already a spring under and it still dosn't sit low enough...Is there any other way. Some guy was telling me to put lift block on top of the springs and then put the axle on the lift blocks to lower in stead of lift it.
Unread 11-11-2006, 04:15 PM   #9
UltimatE
Resident Audio Guru
UltimatE's Avatar
Spring under with stock springs should easily tag the bumpstops ...
-Matt
White '94 YJ Sport
Unread 11-11-2006, 04:36 PM   #10
Bryson
Yeah...spring under has to be at least a 3" drop just from looking at the geometry.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote Quick reply to this message
Unread 11-12-2006, 11:49 AM   #11
Wazzuppiggy156
1995 XJ Cherokee
i don't know if maybe mine is goofy or something but I've got a spring under and have still got a solid 3" of travel before touching the bumpstops. idk if thats wierd or not...
Unread 11-12-2006, 12:06 PM   #12
Twsty
1988 MJ Comanche
your profile says you have a D35 front....true?
1988 MJ 4.0/D60/14b/5.38/42s/PSC hydro
1995 XJ 4.0/AW4/231/JCR sliders/235s on KJ 16" wheels
1996 F350 PSD/ZF5, 375hp/692ftlbs
Twsty is offline   Reply With Quote Quick reply to this message
Unread 11-12-2006, 03:36 PM   #13
red96jeep
dude it's a jeep if you want somthing THAT low get an s-10 lol. if you do want it lower then yes put like an inch lift block in between the spring and axle, now come on was that to hard to think of?
5 inch lift
rear ended= totaled
project vehicle
Unread 11-12-2006, 04:10 PM   #14
XJ4oh
1997 XJ Cherokee
What is involved in a spring under setup? I know what the end product is, just not sure how to go about doing it.
Do you flip the axle or something so the leaf perches are facing under?
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline   Reply With Quote Quick reply to this message
Unread 11-12-2006, 04:49 PM   #15
red96jeep
no cut off the leaf perches then ether re use the old ones if they are in good shape or get new ones and weld them back on on the otherside of the axle.
5 inch lift
rear ended= totaled
project vehicle
