for the guys with lowered xj's - Page 3 - JeepForum.com
post #31 of 33 Old 03-11-2007, 10:04 PM
seanyb505
1997 XJ Cherokee
I did it today, took me about an hour. It looks good but not like a horrible road scrapping crapper. I havent been able to test the limits, but it feels more capable.
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
seanyb505 is offline
post #32 of 33 Old 05-28-2010, 11:45 AM
rocksbite
you can go more then 2" in the front. the axle sitting on the bump stops is still 3 or 4 inches from the oilpan. i swapped in tj coils then cut out one coil from the bottom. cutting the coil out only changes the ride height not the spring rate. the only time i hit the bumps in the front is when i hit a hugh pot hole or rr tracks. as far as the rear i cut the lenght of the leafs down to match the next one..
92 wrangler, comp cut, flat fenders, 101" wb, np231/d300 dual cases, d44's, rear disc brakes, s10 blazer leafs, 36" goodyear military oz, BLUE JEEP CLUB MEMBER #157
rocksbite is offline
post #33 of 33 Old 03-18-2012, 10:30 AM
solidsnake1761
Ok so how much do you need to cut of the ford springs i think if you did a spring under on a Cherokee it would be to low and would need to buy lift springs
solidsnake1761 is offline
Lowered (between the rails) winch bumper design/build YJhobby Fabrication Shop 15 02-13-2010 07:02 AM
pic request..i need a lowered zj plz cherokeed96 Street Jeep Forum 1 02-14-2009 05:36 PM
lowered 2wd comanchee? fozzies jeep Street Jeep Forum 1 10-28-2006 09:55 PM
So I lowered my jeep -pics- UltimatE Street Jeep Forum 17 07-09-2006 12:34 PM
Lowered & Tuned Jeeps - Please post pics here! TIA 2ksaharawhite Tires & Wheels 11 07-21-2003 03:45 PM
