Quantcast Guess what I just ordered - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > Guess what I just ordered
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 01-10-2009, 05:40 PM   #16
SuperStreetJeep
1993 XJ Cherokee
Originally Posted by alexrule123 View Post
Well since they don't have an idea when they would ever be getting any of the parts in I bought something else for now. So I got a pair of CDT Audio EF-61FG/TW25 PRO CDT with the Upgraded TW-25 Tweeters, I am hoping they will some somewhat if not as amazing as my friend's pair of image dynamics XS-57 components.
you bought god damn audio?!?!?! whats wrong with you?
SuperStreetJeep is offline   Reply With Quote
Old 01-10-2009, 11:41 PM   #17
alexrule123
Universal Cereal Bus
alexrule123's Avatar
I couldn't help it..the deal was too good to turn down
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is online now   Reply With Quote
Old 01-24-2009, 08:23 AM   #18
alexrule123
Well I got an email the other day and both the cam and headgasket will be shipping out on Monday.
Old 01-26-2009, 06:47 PM   #19
n20jeep
1993 XJ Cherokee
better put them *****es in ASAP
n20jeep is offline   Reply With Quote
Old 01-30-2009, 02:40 PM   #20
alexrule123
Well I came home to a nice surprise today from ups =D
and my favorite
Old 02-19-2009, 08:07 PM   #21
93BlackJeep
Have you ever taken your Jeep down the 1/4 mile, or is there any way you could do it before and after you put the cam and ported head on? I'm really interested in seeing how much you gain from doing this because I have a heavily ported head on my 4.0 and honestly the damn thing isn't a lot faster than a stock 4.0. To prove my point, my Jeep ran a best of 16.58 @ 81 in only 1700d/a, so even at sea level, in like 50 degree temps, with no humidity it would only run a 16.28. To me that seems pretty pathetic considering my motor is bored out .040 over (~30k on rebuild, and has had full tuneup in last 10k), I have a bored tb, a gutted cat and 2.25" catback, the 99+ intake, and I took the dent out of the stock downpipe. I also ran without the spare and I'm on 225/75/15s. Basically what I'm trying to say is that I hope your head work and cam don't prove to be as useless as my modifications did.
93BlackJeep is offline   Reply With Quote
Old 02-19-2009, 09:29 PM   #22
alexrule123
No I haven't taken it to the strip. All I know is that my jeep right now can beat cars that are supposed to be in the mid to high 15 sec 1/4 mile range.
Old 02-19-2009, 10:32 PM   #23
93BlackJeep
Hahahaha, yeah I know all about that, I beat a couple of "15 second cars", the problem was that their drivers sucked.
Old 02-19-2009, 11:25 PM   #24
alexrule123
Yeah lol so I don't really know how fast my jeep would run
Old 02-20-2009, 08:45 AM   #25
paroxysym
2007 WK
i had that cam/lifter package installed in my tj when one of my lifters was getting on my nerves. rode great, and performed well. you will like it.
07 WK Laredo 4.7
QT II - BA sound - 6k HID fogs/lows - Daystar 2" BB - Bilstein HDs - Addco Rear - SRT front - 2" Bwoody links - 255/75 GY Silent Armors - 1/4" wheel spacers - Black JK Moabs - SC Flashpaq - Fastman TB - 22" Magnaflow - Tinted tails
paroxysym is offline   Reply With Quote
Old 02-20-2009, 12:47 PM   #26
SuperStreetJeep
1993 XJ Cherokee
hmm...ive mentioned this before. where was the porting done? was a flow bench used? and did it receive a polish?
a port job can actually hinder performance if not done properly. are you using stock valves in your head? factory exhaust manifold?
because with a 2wd XJ, your times dont seem right. especially with the .040 rebuild.
Old 02-20-2009, 12:58 PM   #27
93BlackJeep
My XJ is 4wd, and it was home ported & the exhaust ports were polished until they were smooth and shiny, the intakes were left a little rougher. I can post pics of it to show how much work was done, but it really says nothing of the flow characteristics because it was never tested on a flow bench. Oh, the combustion chambers were also polished & stock valves were used.
Old 02-23-2009, 09:18 AM   #28
beterthnKillazz
And after all the work you put into that head...my jeep will
STILL be faster...its ok tho, your exaust stops at the cat...you still look kool to some ppl.
beterthnKillazz is offline   Reply With Quote
Old 02-23-2009, 09:47 AM   #29
SoloCamo
1988 MJ Comanche
You need to free up that exhaust a bit more...
Also, how bad are you spinning with those 225's? My street 235's don't even give me enough traction...but then again, mine's a comanche so their is no weight over the rear in comparison.
Regardless, throw on 2.5" cat back, and potentially get some better tires and you should be well into the 15's. Also, what intake are you running? I'm assuming at the very least a k&n drop in?
and who are you?
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline   Reply With Quote
Old 02-23-2009, 11:13 AM   #30
93BlackJeep
^I was launching at 13-1400rpm with no wheelspin, any higher and I was spinning like crazy and in the 17s. The intake at the time was totally stock (silencer included) with a new paper filter. I did at one point put a k&n cone on but it honestly wasn't any faster, and throttle response seemed worse, maybe due to not having a heat shield on it. I might try a different cat back and the intake again with a heat shield, but I'm really not too optimistic about the outcome. On a side note, does anyone here notice that their xj shifts faster and harder in the 3 position than it does in drive?
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
