Quantcast Got bored today - Page 4 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > Got bored today
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 02-21-2007, 11:49 PM   #46
XJ4oh
1997 XJ Cherokee
I just kind of scanned through this...
You guys are saying you did this with a sanding drum attatched to a drill? And just opening it up to 60mm correct?
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
30x9.5 Kumho M/T's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
XJ4oh is offline   Reply With Quote
Old 02-22-2007, 12:26 AM   #47
955speedCh
1995 XJ Cherokee
yes. but has anyone bored the whole thing out to 62mm and made a new butterfly? or will this be overkill on a stock motor?
1995 4.0L 5 speed 154,xxx
@Hofstra
Spider Monkey Off-Roading
955speedCh is offline   Reply With Quote
Old 02-22-2007, 06:04 AM   #48
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
XJ40h: Yes and Yes or if you can find someone with a metal lathe that is probaly better.
955speedch: ive never seen anyone do that before, i know you can buy them that way. After taking everything apart, i see how easy it would be to make a new butterfly. You can also buy 62mm buterflys from a place called xj arrmor (google it)
I think it is overkill on a stock engine, but if you have some bolt on mods (muffler, cold air intake) then it is better than the 60
Arcticcat843 is offline   Reply With Quote
Old 02-22-2007, 11:29 AM   #49
955speedCh
1995 XJ Cherokee
yeah i have a muffler and cone filter etc. and i have access to a machine shop here at school so i might try it out
@Hofstra
Old 02-22-2007, 11:31 AM   #50
jeeptorino68
1992 XJ Cherokee
what do you guys think works better with the drill press, flap wheel or sanding drum? also how do you center the Tb under the press, or does it "self center" due to the close size of the sanding wheel compared to the TB
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline   Reply With Quote
Old 02-22-2007, 11:37 AM   #51
alexrule123
Universal Cereal Bus
alexrule123's Avatar
easy..you eyeball it i would say a flap wheel would be faster, but i can do one in under 15 min with the sanding drum, that is factoring the time needed for the throttle body to cool between sandings.
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is offline   Reply With Quote
Old 02-22-2007, 01:31 PM   #52
jeeptorino68
1992 XJ Cherokee
i read i think on here that someone cut every other flap off of thier flap wheel? why is that doe sit sadn smoother that way? how long shoudl i sand before letting it sit to cool off?
do you guys think i shoudl get a spare Tb from the JY first? and then if all goes well i can jsut sell my stock one or something
thanks
Kyle
Old 02-22-2007, 02:12 PM   #53
mrnobody_01
jeeptorino68,
yeah, I found the wheel and actually had to cut out more than everyother-cut 2 leave 1 cut 2 etc. The reason was that the the smaller dia. portion of the TB is 54 ish mm's which computes to aprox 2.2 inches. And since I was using a 3in flap wheel I needed to lose that extra dia. yet still have the sanding power. In short, it was to be able to fit the wheel into the TB. Even then it was tuff. If you have one, you could use a piston ring compressor but youd need a POWERFUL drill press and tighten down the chuck really tight. I tried the drum later and -for me- it was a little harder to get the walls smoother and even with the upper area.
Kirt
"Cogito Ergo Zoom" I Think Therefor I Go Fast"
'95 XJ 2-Dr Stoker soon-to-be Stroker, suspension sags on drivers side for faster left turns, current body armor is mud which protects against harmful paint destroying UV.
mrnobody_01 is offline   Reply With Quote
Old 02-22-2007, 04:19 PM   #54
jeeptorino68
1992 XJ Cherokee
cool thanks for the info, so you think if i used a flap wehel closer to 2 inch dia. i will have to cut fewer if any out of the wheel? the flap wheel route sounds like it willbe the easiest. im trying to keep things cheap so this sounds like just the ticket.
speaking of which has anyones mileage gone down since boring the TB? or do you guys alway shave ur foot in the gas now haha
Kyle
Old 02-22-2007, 07:36 PM   #55
mrnobody_01
If you went with a smaller wheel don't go below 2.5in. The flaps wear-out fast and you need alot of surface area to do the sanding. I couldn't find any smaller than 3 but bigger than 1.5
Kirt
Old 02-22-2007, 09:33 PM   #56
XJ4oh
1997 XJ Cherokee
Interesting. So its a 2" sanding drum for 60mm?
Baja Aux. Lighting.
Old 02-22-2007, 10:17 PM   #57
GrayBomb
1989 XJ Cherokee
thats what i used it worked out nice any larger wouldnt fit
For Sale: 89' Limited w/ Renix. Performance:Custom Cold Air Intake, Air Temp Conversion, Map Adjuster, Throttle Body Conversion Bored, 99+ intake manifold, 98 injectors w/ 99 fuel rail, bumped fuel pressure, Borla Wrapped Header, 2.5 in exhaust header back, open loop cooling, electric fan conversion, SS brake lines, 96+ brake booster and still getting 20 mpg highway
For sale link
GrayBomb is offline   Reply With Quote
Old 02-25-2007, 08:18 PM   #58
bigjohnson69
so, could I turn a throttle body on a lathe to 62 mm if I got a new throttle plate?
White 1995 Jeep XJ 4.0HO
5-speed
3" HD OME Lift
31x10.5R15 BFG Rugged Trail T/A's On 15x7 Ansen Sprints - Summer
30x9.5R15 804 Studed Traction Tires on Stock Wheels - Winter
Dual Outlet Flowmaster Super 40
bigjohnson69 is offline   Reply With Quote
Old 02-25-2007, 08:26 PM   #59
alexrule123
yes you can
Glock Forum
