Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > General Technical Discussions > Street Jeep Forum
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old02-11-2007, 03:15 PM #1
alexrule123
alexrule123's Avatar
Send a message via AIM to alexrule123
Got bored today
So i decided to mess around with the drill press i got for $40 from harbor freight and bore a throttle body.
here is the result (stock on the left, bored on the right)
I put it on Rasta_Coty's jeep, since i already have a bored throttle body, and noticed there was a definate increase in power and it only took me 15 min to do .
Now i can mess around and see what i can do with the spare throttle body
Check out my cardomain site: http://www.cardomain.com/ride/2313036 Current Mods: Bored TB│ TB Spacer│ Homemade air intake│ Dynomax Cat-back│Magnaflow High flow cat│ Full Accel ignition upgrades │Borla Clone Header│Mopar Stage 2 cam │ Transmission Cooler │ Addco front and rear sway bars │Rear Disk Conversion
alexrule123 is offline   Reply With Quote
Old02-11-2007, 03:32 PM #2
Rasta_Coty
dang he's lucky...lol
[SIZE="1"]1996 Jeep Cherokee || 4.5 in. RC || 4.0 liter I-6 high output || 33 x 12.50 BFG All Terrain T/A KO, 16x8 American Racing rims || Rusty's Air Tube w/ K&N 9in. Cone Filter || Throttle Body Spacer || Bored TB || Flowmaster Regular 40 || 99+ Intake Manifold Swap || Auto Meter (Trans Temp. | Water Temp. | Volt) Gauges || Pioneer 5800 HU || Hifonics 1606 Amp || (2) Kicker Comp Cvr 15's || 1/0ga. wiring || Vented box || Yellow Top || Tranny Cooler || Bushwackers || [/SIZE]
[B][SIZE="3"][url]http://www.cardomain.com/ride/2218603[/url] Updated 2/4/07[/SIZE][/B]
Rasta_Coty is offline   Reply With Quote
Old02-11-2007, 03:51 PM #3
alexrule123
Old02-11-2007, 03:56 PM #4
UltimatE
Resident Audio Expert
UltimatE's Avatar
I got one of them in my garage (the drill press) Never used it though
Looks good. Any whistle? I know mine gets annoying sometimes.
White '94 YJ - Specs in profile.
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, 31x10.5r15, American Racing Atlas Rims, Addco Front Swaybar
UltimatE is offline   Reply With Quote
Old02-11-2007, 03:58 PM #5
basso4735
basso4735's Avatar
1997 XJ Cherokee
i think this might be next weekends project as we just bought a brand new craftsman drill press. what grit sand did you use?
BBBBuild Thread
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Next step: skids and hitch
Anyone selling 31" MT's, let me know!
basso4735 is offline   Reply With Quote
Old02-11-2007, 04:13 PM #6
alexrule123
the spacer makes it whisle more than anything..but at about 1/4 throttle it kinda sounds like a turbo spooling up.....kinda..the looks people give me are hilarious, and coty's jeep does it better then mine
Old02-11-2007, 04:14 PM #7
alexrule123
i just went to harbor freight and got the drum sander kit...but it think it was like 80 grit and i used the medium speed setting...like 1120rpms..620 was too slow and 3200 seemed a bit dangerious
Old02-11-2007, 04:56 PM #8
Rasta_Coty
yeah even at 1120rpm's we still about died
Old02-11-2007, 05:07 PM #9
alexrule123
yeah...lets not bring that up again....
Old02-11-2007, 05:08 PM #10
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
Send a message via AIM to Arcticcat843
Details !!!!
I have a drill press, How would i go about doing this.
Is it as simple as it looks, just sand it our so it is the same size from top to bottom?
Anything i should watch out for?
I think i might try this, But im afraid i will screw it up (i dont have a spare)
Arcticcat843 is offline   Reply With Quote
Old02-11-2007, 05:18 PM #11
alexrule123
Originally Posted by Arcticcat843
Details !!!!
i bought a spare from a junkyard for $25, so if i messed up no big deal. To begin with you are not going to be going all the way through the throttle body. First you flip it upside down and measure how far the butterfly valve is...this is the "danger zone"..you do not want to go past this! Then remove all the sensors. Then you remove the valve by removing the 2 screws that hold it in and letting the valve slid through the top of the throttle body. then you pull out the shaft. From there i took the gasket for the throttle body and centered it on the bottom of the throttle body and marked the inside of the gasket so i knew how much to remove (the gasket is 60mm in diameter). Then i just took that small drum sander and worked my way around. I tried making the drum bigger by adding more sanding paper, but that didn't work out too well . all you want to do is remove that little lip around the bottom. also if you are by yourself this could be dangerous. i had coty hold the handle that moved the drill down while i used 2 hands to hold on to the throttle body...not the safest thing to do, but we got it done. Also i set the depth gauge on the drill to only go so far down as to not pass the "danger zone".
if you need more pics let me know....i need to mess with my spare tb soon
Old02-11-2007, 05:26 PM #12
Arcticcat843
dakuda is a god
Cool, maybe i will stop by the JY and see how much they will charge for one.
They will probly tell me i have to buy the whole intake
But it cant hurt to give it a shot.
How much of a gain did you notice, was it worth doing it?
Ive heard there is a good gain in torque if you have a free flowing exhaust and a cone filter
Oh and more pics are always good
What are you going todo to the spare one?
Old02-11-2007, 05:30 PM #13
pro street jeep
pro street jeep's Avatar
1985 XJ Cherokee
Send a message via AIM to pro street jeep Send a message via Yahoo to pro street jeep
that looks pretty good. i have a throttle body i think ill try that too. seems easy to do.
"prostreet xj cant be beat"
1985 2dr 2wd 454 smallblock chevy and now 4 stages of nitrous.
www.prostreetjeep.com http://myspace.com/prostreetjeep
now building "prostreetjeep II"
pro street jeep is offline   Reply With Quote
Old02-11-2007, 05:34 PM #14
alexrule123
coty's is probably as fast as mine now...but we still have to test that out It puts you back in your seat now..unlike before
with the spare i want to experiment with different opening sizes
edit: and more pics soon
Old02-11-2007, 05:35 PM #15
alexrule123
yeah, it only took me 15 min to do, but this was not the first one i have done..but the first one i did was on a lathe so it was a little different
? on bored 258 muddmonky Engines & Drivetrain 2 04-28-2008 07:48 PM
got bored today Rasta_Coty Street Jeep Forum 13 12-27-2006 12:22 AM
Bored TB XJ_HORNE Street Jeep Forum 5 06-25-2006 11:56 AM
Got Bored today. my Mock Roll Cage 92 Green YJ Fabrication Shop 5 01-31-2006 05:01 AM
Got bored the other day AdamB Cheap Trick & Fixes 8 09-24-2005 10:23 AM
The time now is 06:50 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
