egine won't turn - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > egine won't turn
Unread 10-06-2013, 06:50 PM   #1
emilekm
egine won't turn
Hi guys new to the jeep sence just bought a 91 wrangler. Needed new exhaust mainfold and water pump. No problem accomplished both between yesterday and today. Started it up anh took it for a short ride all seemed good went home shut off and had dinner. Wanted to get something from the store when i went to start it it was skwelling like a pig. Reved it a couple of times nothing high and sound did not go away. Shut it off thought the altnator went but it seems good. Now it will not start , i have power to all electric but engine will not turn over. Just turn the key and nothing.
I did find that i forgot to make an electrical connection from the fuel rail electrical harness to the plug underneath the motor. Plugged that in and still nothing. Any help would be appreciated thanks in advance
Emil
emilekm is offline   Reply With Quote Quick reply to this message
Unread 10-07-2013, 04:51 PM   #2
yogi22
Hi could you ensure that the serpentine belt was routed correctly after the water pump change please?
yogi22 is offline   Reply With Quote Quick reply to this message
