Do-It-Yourself Window Tint - Page 2 - JeepForum.com
post #16 of 45 Old 02-07-2011, 07:52 PM
Gaboy92
Yea I don't know that I would try to do it myself. But I really want my front windows tinted but I have a soft top does anybody know if that is even possible and if it isnt is there somewhere that I can buy them?
The bigger, the bader, the louder, the better end of story!!
Gaboy92 is offline
post #17 of 45 Old 02-11-2011, 02:56 PM
gqmdl0617
Just a tip I noticed when I had mine done professionally. Once you cut it to the right size, use a heat gun carefully to get the tint to follow the curve of the window. Just my .02.
White 2000 Grand Cherokee Laredo: 2" Fat Bobs BDS Springs with Bilstein 5100's, Addco sway bar, Black on Black heated leather, full limited wood grain, RB1, Mopar Ipod kit, 1000w of Kicker bass, 500w of lighting, Gen III projectors/5000K HIDs, Smoked full LED tails, 100w Whelen PA/Electric Air Horn with speaker mounted behind grill, Interior LED upgrade, 120v AC in the front and the back, Midland CB, PR-106 digital trunking scanner, yada yada yada. Just another WJ
gqmdl0617 is offline
post #18 of 45 Old 02-23-2011, 05:52 PM
muddr1
I did mine on the back windaow of my tj, I had the top off and it was easier. if you have no patience, dont try it. I did one window twice. Doesnt look too bad, but still not profesional. Take your time, if you dont like it, rip it off, start over or have someone else do it. But give it a try anyway.
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #19 of 45 Old 02-24-2011, 12:05 PM
Fillergirl
1988 XJ Cherokee
Originally Posted by NYJeepGuy View Post
Tinting is an art. Spend the $60 and have a shop do it.
Wait, it only costs 60$????
Fillergirl is offline
post #20 of 45 Old 02-24-2011, 12:39 PM
NateRomanowski
I have tried, & failed, i suck at anything that need an artistic touch.
Hated to do it, but i paid the man. Worth every penny.
Good luck.
NateRomanowski is offline
post #21 of 45 Old 02-24-2011, 12:42 PM
Hussler
1992 XJ Cherokee
Its a miserable, miserable job especially on the back windows and hatch. Mine turned out good but thats an hour and a half of my life gone to the wind. I should of just had a shop do it
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #22 of 45 Old 03-05-2011, 09:45 AM
ivounnerry
if you're not good on doing it by yourself, then look for some pro to do it. but there's a lot of kits out there.. it just depends on your budget.
eBooks and Guides you need / http://fleetdigital.com
ivounnerry is offline
post #23 of 45 Old 03-05-2011, 01:40 PM
kshears
I do everything myself,the money you save can be spent on more mods.the easiest thing to do is FOLLOW THE INSTRUCTIONS and remove the door panels.
kshears is offline
post #24 of 45 Old 03-17-2011, 12:30 AM
utahjoe
I used to do tint, it takes patience and a lot of ruined film. You can use a mixture of soap and water or alcohol and water to reduce the tackiness. Get a good squeegee. I like the turbo yellow ones http://www.tintsupply.com/tinting-squeegees.htm Dont be afraid to get the tint too wet either. Buy a roll if its your first time and intent to learn. You will probably screw up a few times. Also remove window felts so you can tint past that and not have to worry bout peeling. Start on something easy like a back window. Good luck
utahjoe is offline
post #25 of 45 Old 03-17-2011, 12:31 AM
utahjoe
Also spend some time watching youtube videos. You would be surprised what you can learn on youtube
utahjoe is offline
post #26 of 45 Old 03-24-2011, 07:25 PM
lanrod
As much as you may get fulfillment from doing things yourself, sometimes it pays to have a pro do it. For me, this would be one of those times.
lanrod is offline
post #27 of 45 Old 03-24-2011, 09:10 PM
Gaboy92
Yep im going to have to agree
Gaboy92 is offline
post #28 of 45 Old 04-21-2011, 04:28 PM
ThaPresident
i think I might give it a try. I'll practice on my f150 first since that's more of a heap than my jeep. I'll post pics if it does look like ****
ThaPresident is offline
post #29 of 45 Old 07-20-2011, 10:41 PM
jjmontess
Just use lots of water, it'll let you move the tint around until you get it perfect...once it dries, you better have it in position because it's really sticky.
jjmontess is offline
post #30 of 45 Old 07-20-2011, 10:45 PM
Meep97
2009 JK Wrangler
You need soap in that water. Just water will not work.
Meep97 is offline
Window Tint for Soft Top JeepWrangler05 General Jeep & Off-Road Equipment 5 06-02-2010 02:38 PM
Where can i find Window tint? bgoman General Jeep & Off-Road Equipment 17 10-05-2008 06:17 PM
window tint jdhughes General Jeep & Off-Road Equipment 12 01-04-2008 07:19 PM
Permanent Window Tint? Grinner Street Jeep Forum 5 09-01-2007 09:47 AM
Busted for Window Tint MendoXJ General Jeep & Off-Road Equipment 19 05-22-2003 05:34 AM
