Custom Audio and Interior Pics Sticky
#61 | |
I thought I would show off some of the eye candy that came yesterday. I have more stuff coming also.
Kicker ZX1000.1 Kicker ZX350.4 FI Audio 12" Q w/ BP Power option Stinger 2 channel RCAs Stinger 4 Channel RCAs 50' spool Streetwires 14G Speaker wire Kicker 0 gauge wiring kit(not pictured) ![]() ![]() ![]() ![]() Its going into this ![]()
#62 |
#63 |
99 xj sport aka BLACK BETTY |
#64 |
how did you make the dash so bright? looks awesome Higgs98XJ
#65 |
anyone have any led,neon in the interior?
#66 |
I should hope not!
[quote=XJ4oh]I did a top speed run today. I hit teh NOS when I was at like 100 and my speedo bent around like 3 times, I guess I was going like 300 mph. It felt like I was sitting still, I ran out of road but luckily I was going so fast that I hit a bump and took off. I guess the Supra wing really helped out, luckily I landed in a lake and my wheels were spinning so fastz that I scrambled across it like those crazy scandanavians with their 4x4s that walk on wata. I go off of the lake just in time to hit a dirt field right before my flux capacitor quite.[/quote] |
#67 |
No custom TJ's or LJ's? Why all XJ's?!?!?
Don't get me wrong I love XJ's (owned a '95 and '01 and currently own a '00). I know there's custom Wrangler interiors out there. Where are ya? ... ![]() |
#68 |
#69 | |
YEA YEA YEA (beavis voice) haha
WTB WHEELS. .......Ecco's OR TJ Canyons. Send PM with what you have Bruiser -- 93 XJ Sport. 9.5" of lift on 35"" Claws, Locked front & Rear, and some other crap. Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Quote:
#70 |
Stealing someone else's pics but here is the start of mine!
Alpine SPX-F17T
Type Component 3-way speaker Power Handling (peak/RMS) 300/75 W Impedance 4 W Frequency Response 30-35 kHz Net Weight 8.6 kg Drivers General Speaker size 6.5” 5.25” 28 mm Speaker Type Bass Midrange Tweeter Power Handling (RMS) 80 W 70 W 150 W Voice Coil Impedance (nom) 4 W 4 W 4 W Frequency Response (-10dB) 10 kHz 10 kHz >40 kHz Sensitivity (@2.83V/1m) 89.5 dB 88 dB 90.5 dB Voice Coil Diameter 26 mm 26 mm 28 mm Linear Excursion (Xmax) 5 mm 2 mm 0.25 mm Mechanical Excursion (p-p) 18 mm 14 mm 2.6 mm Mechanical Frame Material Aluminium Aluminium Aluminium/ABS Magnetic Material Strontium Strontium Neodymium Diaphragm Material Wood Fiber Wood Fiber Textile Diaphragm Shape Curved NRSC Curved NRSC Dome Surround Material and Type LRMS Styrene LRMS Styrene Speaker Weight 1320 g 1140 g 108 g Woofer Magnet Weight 910 g 810 g Magnet System Type T-drive T-drive Depth 70.8 mm/ 2.789” 62.1mm/2.444” 35.7mm/1.405” Cut-out diameter 132.1 mm/5.199” 117mm / 4,606” 40,8mm / 1,606” Thiele/Small ReDC 3.1 W 3.1 W 3.5 W Fs 44 Hz 40 Hz 750 Hz Qts 0.55 0.31 - - Qms 5.65 4.0 - - Qes 0.61 0.33 - - Vas 28 liters 17 liters - Sd 129 cm2 74 cm2 8.0 cm2 Le 0.4 mH 0.3 mH 0.02 mH Cms 1.1 mm/N 2.1 mm/N - Mms 11.5 g 7.5 g 0.4 g Bl 4.0 T-m 4.2 T-m 2.7 T-m Sealed box Volume (Butterworth) 38 liters 3.5 liters - ![]() ![]() ![]() ![]() ![]() Alpine MRD-M500 Sub Amp ![]() Details: * 250 watts RMS x 1 at 4 ohms * 500 watts RMS x 1 at 2 ohms * MOSFET power supply and output stage * STAR Topology for cleaner sound * Bass Engine® features: o low-pass digital crossover, 30-200 Hz, 24 dB/octave o variable subsonic filter (15-50 Hz in 5 Hz steps) o parametric EQ variable from 30-160 Hz, ±12 dB o Bass Compensator enhances low-end definition * top-mounted digital control center with cover * time correction 0-10 milliseconds in 0.1ms steps * phase adjustment 0-180° * turn-on delay * digital readout * detachable front cover * blue power LED * preamp inputs and outputs * requires 4-gauge power and ground leads — wiring and hardware not included with amplifier * extra-large gold-plated terminals * 12-3/8"W x 2-11/16"H x 11-1/2"D (10"D without front cover) Alpine MRV-T420 Front Stage ![]() Details: * 110 watts RMS x 2 at 4 ohms * 170 watts RMS x 2 at 2 ohms * 340 watts RMS x 1 in bridged mode * stereo or bridged mono output * Tri-way capable (Tri-Way crossover required) * requires 8-gauge power and ground leads — wiring and hardware not included with amplifier * Bass Engine® features: o variable 15-400 Hz high-pass/30-400 Hz low-pass crossovers, 12 dB/octave o variable Bass EQ (up to 12 dB bass boost at 50 Hz) * MOSFET power supply * STAR Topology (minimizes internal noise and prevents ground interference) * oversized power and ground connections * gold-plated screw terminals * top-mounted controls with cover * detachable front cover * blue power LED Legacy 1 Farad Digital Capacitor ![]()
[I]I [B]shop[/B] in the salvage yard![/I] |
#71 |
Subwoofer - continued from above - 10 pic limit
Infinity Perfect 10 DVC Subwoofer
I made this 1 cubic foot sealed box for another vehicle, and most likely will be building a custom enclosure that mimicks the Stealthbox in the rear passenger side area cutout in the cargo area. ![]() ![]() Here are a couple of pics of the box being built in my shop. It was made using 1 1/2" thick MDF, rabbit joints for maximum glue surface area and polyester epoxy. ![]() ![]()
#72 |
I think this thread needs something...
MORE BANDPASS!
Black 1996 Jeep Cherokee Sport, 4.0, 4WD, NP231. 31 inch Yokohama Geolanders. 3" Rough Country AAL Kit. ZJ tierod. C4x4 Front tow hooks. Nates 4x4 rear bumper w/receiver and shackles Iron rock offroad double shear adj trackbar |
#73 |
![]() ![]() ![]() Pioneer Premiere head unit Pioneer Premiere class d 2000w amp 2 Kicker L5 subs
Film Maker/Graphic Designer [B]Heights 4x4[/B] 00' XJ 93' XJ Country |
#75 |
2000 jeep grand limited
hard lined radar detector LED signal stearing wheel conrols (so i can still use the volume/ect controls with the new head) 1000 watt california amp Sony sub (cheap yes but has 0 question replacement... i have gone though 8 subs with this amp ranging from MTX to you name it.... and this one takes it) bose speaker replacement set up though the entire car 450 sony amp powers the interior Jenson touch screen DVD/nav/XM/PS2 fiberglass sub enclosure... when i first made it i wrapped it in the same leather as my interior... but then i ripped it a few weeks later moving a chopper frame i am building... ooh well ooh ya and i do have a full size compassitor as well ![]() ![]()
Joe K. "if you can buy it, you can build it BETTER"! 2000 Jeep grand WJ limited, 245/75/16, cool air intake, Thrust 2 chamber muffler, 2in bb, rough country shocks, slotted and drilled rotors, powder coated calipers, custom made CAI, ported and polished throttle body, lots of powder coating and blacked out parts |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
