Chrysler to Ford 8.8 axle swap? - JeepForum.com
post #1 of 5 Old 05-26-2008, 06:06 PM Thread Starter
Shadow83
I have a 92 4.0 Cherokee 2 WD with a very noisy Chrysler rear axle. I was watching Trucks on Spike and they said that the Ford 8.8 96 and later was a direct bolt up swap for the Cherokee but did not say whether it was for a Dana or Chrysler axle. Will the Ford 8,8 swap with the Chrysler axle?
1992 Lerado
4.0L, auto, 2WD
240k miles and starting to show her age.
South Florida
Shadow83 is offline
post #2 of 5 Old 05-27-2008, 10:52 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
i don't recall them saying that in the episode. it will bolt up with some work. you'll need to cut off all of the old ford bracketry and get new u bolt plates and shock mounts welded on before it will bolt into an xj. and you'll need a flange adapter between the pinion and the drive shaft. not really bolt in. but not too much work
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #3 of 5 Old 05-27-2008, 11:57 AM
jeepicon-com
yes, you will more than likely have to burn new perches on it.
jeepicon-com is offline
post #4 of 5 Old 05-29-2008, 01:47 AM
kingofthehill
1990 XJ Cherokee
well worth the work if you think you have the ability to do it
90' XJ 2dr 2wd
Curent issues:
OMFG you don't even want to know
kingofthehill is offline
post #5 of 5 Old 05-29-2008, 09:00 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
They did bolt it up at first, but that was to check pinion angle and set everything up, they went back thru and burned the purches and shock mounts on.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Chrysler 9.25" rear axle RUBtjICON Engines & Drivetrain 4 05-28-2012 09:14 PM
Help with a ford solid axle swap bgstjrkinthwrld Engines & Drivetrain 3 07-22-2007 02:12 PM
Ford Explorer Axle Swap 00Vert Engines & Drivetrain 65 07-02-2006 10:21 PM
Ford 8.8 Axle Swap Stormtrooper Fabrication Shop 12 01-02-2006 07:16 PM
engine swap, 383 chrysler 86cj7 Engines & Drivetrain 1 06-10-2002 01:37 AM
