check engine light constantly coming on - JeepForum.com
post #1 of 3 Old 08-06-2008, 10:29 PM Thread Starter
sascuba
Hey all,
I'm not sure if I have a question or just want to vent. In the past four months or so, I have had my check engine light come on in my xj. The first three times, I noticed nothing out of the ordinary. I took it to the dealer and they flashed the computer. Told me it was a code pertaining to the transmission on all three occasions. Last week, the light came on while I was driving. The XJ felt as though it was running on two or three cylinders. I could only get it up to about 40 mph. Drove it to the dealer. 10 days later they informed me that it was another tranny code and that they finally tracked the problem down to a faulty transmission solenoid (I think they said "the A" solenoid and that the governer wasn't functioning properly). So I shelled out 750.00 (500.00 labor) only to have the light come on about less than an hour after I drove it away. Of course I intend to take it back, but I'm a little pissed because I obviously now feel the repair was incorrect and not needed. What is my recourse if any of you have had the experience. More importantly any thoughts about the Jeep. Thanks
sascuba is offline
post #2 of 3 Old 08-16-2008, 11:50 AM
onefastmoe
Don't know what to tell you but my 99 Cherokee Sport has all the gauges (speedo, tach, fuel, voltage, temp and oil press) turn off for 5-10 minutes every once in a while and then they come back. The check engine light comes on but not the guages light and then the check engine light goes out and the gauges come back a few minutes later. Never any codes though.
Mikey
onefastmoe is offline
post #3 of 3 Old 04-10-2012, 12:44 PM
rhaller82
Would there be some way that the sensor is prolly bad? My oil pressure light has been going off and I just replaced the oil sensor. The light has never turned off since.
rhaller82 is offline
Check engine light haterasfever Engines & Drivetrain 4 07-08-2012 09:23 AM
check engine light on 98 I-6 TXjeep97 Engines & Drivetrain 1 11-06-2004 08:25 AM
check engine light on..........????????? mat25542 Engines & Drivetrain 2 10-24-2004 09:19 AM
Check engine light?? Nymisus Engines & Drivetrain 7 06-04-2004 04:34 PM
Check Engine Light.... Cynic Engines & Drivetrain 1 05-20-2004 04:44 PM
