Cheap Power Mods For The XJ... - Page 2 - JeepForum.com
post #16 of 42 Old 09-29-2006, 10:24 PM
Ivanito
Ivanito's Avatar
Originally Posted by Alexrule123
why do you want one? to use it as a heat shield?
kinda sorta
Ivanito is offline
post #17 of 42 Old 09-29-2006, 10:43 PM
Bryson
Bryson's Avatar
you could also do some head work, like larger valves or bumping up the compression by shaving the head
I thought we were talking about budget mods...
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production -
Owner of Boostwerks.com
Website in development.
Bryson is offline
post #18 of 42 Old 09-30-2006, 10:18 AM
alexrule123
alexrule123's Avatar
true...but if you know someone who does that then you are in luck...and i do, it is just trying to figure out when he has some free time
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #19 of 42 Old 09-30-2006, 11:20 AM
Cherokeegrrl
1992 XJ Cherokee
Budget ... eBay for sure. I got a full K&N FIPK for under $55 ... but I blew the budget with Performance cat, muffler and 62mm TB ...
Cherokeegrrl is offline
post #20 of 42 Old 10-02-2006, 10:23 AM
JEEPINWI
I'm working on my cold air intake. I got the filter off eBay for $19 shipped to me.
http://cgi.ebay.com/ebaymotors/SIMOT...QQcmdZViewItem
I'm using 3" exhaust tubing to connect the filter to the TB elbow which was $6 at an exhaust shop. I'm making a heatshield out of cardboard and wrapping it using one of those windshield sun shades from the dollar store($4). My cold air intake will cost $30.
Brian-
99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears
JEEPINWI is offline
post #21 of 42 Old 10-02-2006, 10:27 AM
JEEPINWI
On another note, I'm also building my stroker on a tight budget. I've been building the stroker for almost 2 years, but I'm not cutting any corners. Almost everything has been bought through eBay. Total cost of my stroker has been about $1300 to get me this:
Brian-
JEEPINWI is offline
post #22 of 42 Old 10-02-2006, 11:52 AM
IVIYTH0S
1993 XJ Cherokee
pretty engine indeed, i would think a bored TB and exhaust so it breathes then poops better, probably a new ignition system and maybe the back seats removed (unless you use them) i run 225/75/R15s on my XJ but i still havent done the TB bore yet, is it worth it or is it all in theory
IVIYTH0S is offline
post #23 of 42 Old 10-02-2006, 12:18 PM
alexrule123
i would say it is worth it....but i bored it myself so all it cost me was time
post #24 of 42 Old 10-02-2006, 01:52 PM
Ivanito
Ivanito's Avatar
I actually got a Fastman for hella cheap. A guy I go to school with sold his cherokee to his sister, so he wanted a stocker to put back on
Ivanito is offline
post #25 of 42 Old 10-02-2006, 02:15 PM
alexrule123
nice
post #26 of 42 Old 10-02-2006, 03:45 PM
alexrule123
just came across this article http://www.angelfire.com/my/fan/IAT_sensor.html apparently relocating the IAT sensor to the airbox increases hp...interesting
post #27 of 42 Old 10-02-2006, 03:48 PM
Ivanito
Ivanito's Avatar
Yup. The way it works (IMO) is like this:
-Cold air comes in from the outside
-It doesn't have enough time to heat up before it gets into the cylinders (plus the intake is plastic)
-The IAT is on the intake manifold
-Although aluminum is a poor conductor of heat, it will still get hot
-It heats up the sensor and makes it think the air is hoter than it really is
Moving it into the air stream will give you a more accurate reading
Ivanito is offline
post #28 of 42 Old 10-02-2006, 03:58 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Except the ECU will only read the IAT at WOT. Hell, let me know how it works. Can't take longer than 5 minutes to do.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #29 of 42 Old 10-02-2006, 06:59 PM
Ivanito
Ivanito's Avatar
Really? Hmm, that is diffrent.
Ivanito is offline
post #30 of 42 Old 10-02-2006, 07:04 PM
Matt Gertsch
www.lp.org
Why's that?
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
What are some Free or cheap mods you did? babaoriley Cheap Tricks & Fixes 97 06-05-2010 10:34 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
