Cheap Power Mods For The XJ... - JeepForum.com
post #1 of 42 Old 09-29-2006, 12:04 PM Thread Starter
n20jeep
n20jeep's Avatar
1993 XJ Cherokee
c'mon, everyones got some cheap ways to get quicker with an XJ....post em up
ill start...
Junkyard Gear Swap (for manual equipted XJ's)- find an auto equipted XJ with the 3.55's, and remove the whole rear axle...then just swap out your stock 3.07 rear end with the Junkyard rear end......the whole swap can be done for well under $200, and can be completed in less than a day....
Adjustable MAP- it will help if you have a few bolton's, and can be made from RadioShack parts for under $20...and instalation is easy...
n20jeep is offline
post #2 of 42 Old 09-29-2006, 01:07 PM
Ivanito
Ivanito's Avatar
Smaller diameter tires Poor man's way to gear change (I did the math, and my gears work out to ~3.70).
Ivanito is offline
post #3 of 42 Old 09-29-2006, 03:43 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
That's why I run 235/75R14s.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 42 Old 09-29-2006, 04:13 PM
alexrule123
alexrule123's Avatar
homemade air intake (I finally re-painted it)
And bored throttle body
i am running the same...except i have 15" rims
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #5 of 42 Old 09-29-2006, 04:18 PM
Ivanito
Ivanito's Avatar
So you are actually slower and your true gearing will be lower than 3.55 :P
Ivanito is offline
post #6 of 42 Old 09-29-2006, 04:20 PM
alexrule123
so...i more then make up for it in raw horsepower
post #7 of 42 Old 09-29-2006, 04:25 PM
Ivanito
Ivanito's Avatar
hahahahahaha, hey, do you still have your stock airbox?
Ivanito is offline
post #8 of 42 Old 09-29-2006, 04:28 PM
alexrule123
yes, but i want to keep it if i ever want to drive through some deep water...again
post #9 of 42 Old 09-29-2006, 04:31 PM
Ivanito
Ivanito's Avatar
dang, Im looking for another one...
Ivanito is offline
post #10 of 42 Old 09-29-2006, 04:39 PM
alexrule123
why do you want one? to use it as a heat shield?
post #11 of 42 Old 09-29-2006, 06:34 PM
Bryson
Bryson's Avatar
The best way to get more power out of any stock engine, for the least amount of money, is to advance timing and run 91 octane. The fixed timing on the 4.0L's will require an adjustable crank position senser. not that expensive, and not that hard to do.
If I want'ed to make the most power out of the 4.0L without going FI I would:
- Cold air intake
- Header
- 2.5" exhaust with flow through mufflers
- advance timing 2-4 degrees
- bump up the fuel pressure 2-3psi.
- Replace cap/rotor, plugs, and wires
- swap out the stock coil for a MSD SS (has far less resistance, and more voltage output than the normal cup style coils).
Theres not much you can do other than that to get more power without going stroker or forced induction.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production -
Owner of Boostwerks.com
Website in development.
Bryson is offline
post #12 of 42 Old 09-29-2006, 07:33 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Geese, I'm surprised no one has listed this one. It should be like the first thing anybody does to gain power.
Put a Type R sticker on your rear, driverside window. Make sure it is exactly 0.25 inches to the left, and 0.125 inches up from the molding in the bottom right corner.
This will surely add at least 20hp straight off the bat. Remember, the more stickers you have, the more HP you will gain! There's no telling how high you can get!
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #13 of 42 Old 09-29-2006, 07:45 PM
alexrule123
- Cold air intake
- Header
you could also do some head work, like larger valves or bumping up the compression by shaving the head
post #14 of 42 Old 09-29-2006, 08:26 PM
fitbmxseries1
1987 YJ Wrangler
hmm where do i get these cool speed stickers i hear so much about?.......... OH nvm they sell them every where! walmart is a huge supplier of stupid type R stickers now.
id recomend starting off on a cold airinake then machine out the TB then do a bettery flowing exhaust. IMO i wouldnt buy a header the stock one works alright. OR for the cheapest way to make your jeep faster then hell!..... well actulay a free way to do it! remove seats carpeting doors..... cut out all extra metal.... drill holes in everything......... weight to power ratio oh yeah baby
fitbmxseries1 is offline
post #15 of 42 Old 09-29-2006, 08:51 PM
alexrule123
don't forget removing the engine..that ought to save you around 500 lbs of dead weight
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 06:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 03:33 PM
What are some Free or cheap mods you did? babaoriley Cheap Tricks & Fixes 97 06-05-2010 11:34 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 03:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-07-2009 12:53 AM
