Quantcast catalytic converter - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > catalytic converter
Old 05-14-2008, 11:57 AM   #1
justinwalden
catalytic converter
i am not deleting it.
my cherokee has 105,000 miles on it and i am about to replace my stock cat back with a dynomax kit. should i replace my cat while im at it? its just rusty and looks like its holding up (wish i could say the same about my muffler ) if i dont replace it now i'll probly have it replaced at my next oil change along with my whole exhaust being wielded together.
thanks
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline   Reply With Quote
Old 05-14-2008, 12:12 PM   #2
polizi212
If your going to have the exhaust work done might as well do it all at the same time. Usually the cat will not need replaced but if you feel the need now is the time to have it taken care of... Just my 2 cents...
2000 Jeep Cherokee Sport.
polizi212 is offline   Reply With Quote
Old 05-14-2008, 12:34 PM   #3
SoloCamo
1988 MJ Comanche
Yea, while the exhaust work is being done, you might as well remove another bottleneck and get a hi-flow cat installed.
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline   Reply With Quote
Old 05-14-2008, 12:37 PM   #4
justinwalden
well it wont be until june or so when i take it in to be worked on. if i do it now maybe in june ill buy a new header
Old 05-14-2008, 06:13 PM   #5
urban-yan
my thoughts exactly
urban-yan is offline   Reply With Quote
Old 05-14-2008, 06:15 PM   #6
SilverXJ
kolak@aol.com has some good prices and will tell you the one you need.
SilverXJ is offline   Reply With Quote
Old 05-14-2008, 06:19 PM   #7
urban-yan
^^ I bought my poly sway bushings from him. He was very easy to deal with.
Old 05-14-2008, 06:54 PM   #8
Mike77
1987 YJ Wrangler
Better to replace it now and avoid having the cat go out a little later after you just put a new muffler on cause if the cat goes out it will blow the guts into the muffler and then you will have to replace both.
Mike77 is offline   Reply With Quote
Glock Forum
