Can I turbo charge my Jeep?? - JeepForum.com
post #1 of 24 Old 09-14-2011, 06:37 PM Thread Starter
tansahara99
I have a 1999 sahara straight 6 wrangler with 167000 miles on it. I am interested in putting a 3t turbo in it. I know theres many jeeps out there that have similiar turbos on them but all I could find was ones with 2.5L 4 cylinders and nothing about a 4.0L straight 6. Is it possible??
tansahara99 is offline
post #2 of 24 Old 09-14-2011, 09:46 PM
JeepinJarhead03
wouldn't do it without freshining up the rings and what not
it's been done - successfully might i add
JeepinJarhead03 is offline
post #3 of 24 Old 09-15-2011, 07:30 PM
TURBevO8
I'll sell you my stock Mitsu 16G cheap! And shipping to Clearfield would be only a couple bucks.
Anything can be done. Will just need a manifold, boost controller, intercooler (maybe), more fuel, and a way to regulate the AFRs.
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is online now
post #4 of 24 Old 10-30-2011, 09:17 AM
alfaitalia
Mines turbocharged.......... but then all 2.7 CRD Grand Cherokees are!! Heh heh!
alfaitalia is offline
post #5 of 24 Old 11-01-2011, 11:12 PM
XJ4oh
1997 XJ Cherokee
What's your reason for wanting to do so, and how much would you be willing to spend?
A boosted 4.0 would be a torque monster, but since there's very little in the way of demand for turbo kits for that application, it won't be cheap.
Don't take it the wrong way, but if you're asking if it can be done, I'm assuming you don't plan on doing much of the work. Labor cost would be silly.
You'd probably be better off looking into a GM LS-engine swap, or even an older Vortech V8, Ford 302, AMC 360, etc.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #6 of 24 Old 11-04-2011, 06:25 PM
EfiniMotorsport
From what I've seen it's not that hard or expensive. I was looking at turboing my 95 Grand. I've got a few pics I can send you if you want. From what I've been able to find out all you really need to do is have a pipe bent up that goes from the exhaust manifold around the front of the motor and mount the turbo on the opposite side. then just connect the exhaust side of the turbo back into the exhaust
EfiniMotorsport is offline
post #7 of 24 Old 11-05-2011, 07:01 AM
alfaitalia
Right....if you are not joking (and I hope you are), if I was you you, with your level of mechanical knowledge, I would just stick to putting fuel in it!!!
"Just have a pipe bent!!!" Physically fitting the turbo is a bit more complex than that. Even forgetting the massive thermal loads on a turbo and its piping (most turbo manifold are cast or titanium for that reason) what about an high pressure oil supply for the turbo? What about extra fuelling you will need (remap or piggy back ECU)?? What about dealing with the extra heat generated buy your engine?? What about lowering the compression ratio (usually needed to allow the use of any meaningful boost)?? What about regearing to deal with the extra power?? What about upgrading the piston/rods to cope with more power than they were ever designed for?? Will the brakes be up to stopping it once on boost!!!??Will you tranny, prop shafts, axles cope?? Etc etc etc. Its a massive (and very expensive if done right) job and one best left to the experts if you dont want to end up with an unreliable, peaking, thirsty motor.
Just my 2 pence worth!!
post #8 of 24 Old 11-06-2011, 07:28 AM
EfiniMotorsport
That would only get the turbo mounted and in a good location. I know there is a lot more to it tan just that but the other posts I've seen mostly revolve around where/how to mount the turbo. I have built my fair share of turbo cars and am currently building a 240 with a turbo skyline motor. I know there is much more than just getting it mounted. I have not personally turbo'ed a jeep but I know you can run about 5-6psi safely on stock internals with the correct fuel mods. Very few manifolds are titanium unless it's a money is no object build. For the most part they are stainless steel. There is no need to regear as you're not adding a ton of power and then it isn't the gear ratio that is the issue it's the strength of the components. With the low amount of boost a healthy drive train will be fine and as long as you're not going 100+ the brakes should be fine too.Check out 505 Performance. They offer turbo kits for jeeps and have a lot of info on it.
post #9 of 24 Old 11-06-2011, 07:50 AM
Bojeepus
505 perfomance are the folks to talk to about turbos and 4.0/4.7's
Bojeepus is offline
post #10 of 24 Old 11-06-2011, 07:31 PM
TurboTPI
I'm going to be doing a turbo setup on my 95 ZJ 4.0. I'm gonna use a stock Buick grand national turbo. It will work well with a 4.0 and you can find them pretty cheap. 5-6lbs of boost will be fine on a stock motor with proper tuning.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #11 of 24 Old 11-08-2011, 08:07 PM
TurboTPI
^ wtf?
TurboTPI is offline
post #12 of 24 Old 11-25-2011, 09:12 PM
kbman
Check out jp magazine they have an article about it
kbman is offline
post #13 of 24 Old 11-30-2011, 08:31 PM
placoo12
Why would you need to worry about any re gearing or more heat from the motor if one would be only putting a couple pounds of boost in his jeep. Of course you would worry about all that if your running 25 pounds through the jeep but i have not read one build that says more than ten pounds through an I6 motor. EfiniMotorsport is trying to give the guy a couple starting out tips not laying it out step by step either so just calm down
[o] [][][][][][] [o]
ZJ LOVE
placoo12 is offline
post #14 of 24 Old 12-11-2011, 09:23 PM
chadlanc
go for it, why not..
chadlanc is offline
post #15 of 24 Old 12-11-2011, 09:34 PM
joshthib
1992 XJ Cherokee
boostwerks makes a kit for the xj so i would contact them for your tj if you seriously want to get some help with the manifold, engine management etc
joshthib is offline
Using my Jeep to charge a smaller battery? JLC08JK Audio, CB & Ham Radios, GPS, & Electrical 5 06-18-2011 02:55 PM
What does your local steel supplier charge for a "cut charge"??? rustywrangler Fabrication Shop 13 03-26-2010 08:46 AM
Turbo Jeep ribs Engines & Drivetrain 5 05-06-2008 08:25 PM
Turbo Jeep Brindle19 Engines & Drivetrain 4 11-02-2005 08:58 PM
Turbo on 98 Jeep!!?? nto898 Engines & Drivetrain 1 12-22-2002 02:10 PM
