Quantcast Bored TB - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > Bored TB
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 06-24-2006, 04:31 PM   #1
XJ_HORNE
Bored TB
What's up everybody! The new guy on the forum. Just wondering how much the bored TB really helps? I've got all the other, TB spacer, C.A. intake, Flowmasters, no converter, and runs pretty well. Thinking of a chip, can anyone recomend one that really works well. And how does the adjustable map sensor work?
Thanks for the info!!
XJ_HORNE is offline   Reply With Quote
Old 06-24-2006, 04:37 PM   #2
red96jeep
chips for jeeps are a waste of money they dont give you enuf of a gain in power to really prove them selvs. so dont waste your money on it lol. but i hear the bored tb really does help do a search for boring out your stock one and saveing your self some money.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline   Reply With Quote
Old 06-24-2006, 05:17 PM   #3
MidnightRacer
Yes, the bored TB is much better than that TB spacer by far, the TB spacer really does not do much for your jeep. Do a search for TB and you will find plenty of threads related to this topic
MidnightRacer is offline   Reply With Quote
Old 06-24-2006, 05:27 PM   #4
alexrule123
Universal Cereal Bus
alexrule123's Avatar
when i bored my tb i noticed an improvement in the acceleration all the way throught the rpm range, but you would probably notice more of an improvement since you have all the other stuff on your jeep
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is offline   Reply With Quote
Old 06-25-2006, 11:16 AM   #5
XJ_HORNE
Thanks everybody. How does the adjustable map sensor work?
Old 06-25-2006, 11:56 AM   #6
LEAD_NOT_FOLLOW
1989 XJ Cherokee
The MAP sensor is the main signal used by the ECU/DME to calibrate the amount of fuel supplied to the engine. It's pretty simple of how it works, basically it's is a three wire pressure sensitive variable resistor. The three wires are the +5 volt input, output voltage to ECU and the ground wire. By increasing the input voltage you can in turn increase the voltage to the ECU/DME which will supply more fuel to the motor.
Hope that explains it enough for you to understand.
LEAD_NOT_FOLLOW is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
