Biggest Rims on XJ - JeepForum.com
post #1 of 24 Old 12-04-2008, 11:12 PM Thread Starter
trouble182002
Biggest Rims on XJ
Does anyone know whats the biggest rims that you can fit on an XJ?? With 18's what size tire can you mount?? Same with 20's?? Stock XJ...
trouble182002 is offline
post #2 of 24 Old 12-05-2008, 12:11 AM
242much
2009 JK Wrangler
um... oh, you're from new york. makes sense now. anyway, how much drivability are you willing to sacrifice? i'm sure with enough trimming and the right set of rims and tires, you could throw some 24's or 26's on it. maybe bigger.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #3 of 24 Old 12-05-2008, 02:44 AM
madrabbitt
madrabbitt's Avatar
no way...
well, lifted maybe
but on a stock XJ i doubt you'll get more then 20's under there
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #4 of 24 Old 12-06-2008, 10:16 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
the new charger rims look great on an XJ IMHO.
Factory Four Link
XJLI is offline
post #5 of 24 Old 12-06-2008, 05:14 PM
SoloCamo
1988 MJ Comanche
Don't play that stereotypical BS.
Anyways, to the OP:
18's is about the biggest you can safely tuck under there with decent tires on a stocker. 18's are the biggest that look good on a XJ/MJ as well.
17's with some good performance tires are the perfect combo for a street XJ, though.
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline
post #6 of 24 Old 12-06-2008, 09:05 PM
TPI Monte SS
Here's what I use on my XJ in the spring/summer/fall. The rim is an 18x7, and tire size is 225/60 18, just about the same height as the original 225/75 15.
Steve Ragusa - North Jersey
'01 XJ - SOLD!
'06 Infiniti G35x - coupe front springs, tint, FX35 18's, hitch for the bike rack.
'03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 50K original miles.
TPI Monte SS is offline
post #7 of 24 Old 12-07-2008, 06:06 PM
Carnutzzz
Finally you post a decent side shot!
How did you remove the cross bars on your roof rack?
Thanks,
Carnutzzz is offline
post #8 of 24 Old 12-10-2008, 10:19 AM
TPI Monte SS
Thanks!! Haha, I know I should have posted one looooooooong ago, just never got around to it.
You just need to remove the Torx bolts that hold the rails onto the roof, then slide off the caps and then the bars will slide off. It's a bit of a PITA but I think it looks much better. Did you ever wind up getting the 18's on yours?
'01 XJ - SOLD!
post #9 of 24 Old 12-12-2008, 06:55 PM
KarenCaren
With proper lift. I think you can fit a 33" tire on that XJ.
KarenCaren is offline
post #10 of 24 Old 12-18-2008, 08:38 AM
Carnutzzz
Ahh ok- thanks.
My 18's are all cleaned-up and sitting in the basement. I bought some well used tires for test fitment purposes, but since they are well-used I'm waiting until I've completed all of my holiday traveling before putting them on. With my sister's wedding, Thanksgiving, etc. I've been driving all over the South East the last few months. Didn't want to hit the road with worn tires and a spare that's now the wrong size.
I'll post some pics in January of my rig with the 300C wheels wearing 235/65/18s at stock ride height. Also leaning towards the OME 2 in. lift, but that won't be until Spring.
Did you re-use your stock lug nuts or get some specific to those wheels?
post #11 of 24 Old 12-18-2008, 08:52 AM
TPI Monte SS
Originally Posted by Carnutzzz View Post
Ahh ok- thanks.
Sounds good! I reused my original lugnuts; they were in good shape, and the taper on them matched the Magnum wheels perfectly. The lug holes are a bit larger because the 300C/Magnum uses a larger wheel stud, but the outer edge along the taper is exactly the same size. And, the center hole is exactly the right size to go over the front hubs. Just tighten them down in a star pattern slowly so they all seat properly, then torque to spec. Make sure you post some pics of your rig when you put the 300 wheels on!
'01 XJ - SOLD!
post #12 of 24 Old 12-18-2008, 09:12 AM
Carnutzzz
Thanks for the lug info.
Pictures soon! Should be 'interesting' with all of that chrome- at least the chrome wheels will match the grill and the rear hatch trim which are chrome from the factory. I'll be blinging for sure.
The stock wheels are going to get some Mud-Terrains or something similar so I'll be able to completely change the look of my Jeep at whim within an hour and 2 beers in the garage.
post #13 of 24 Old 12-19-2008, 06:39 PM
Brizio
1991 FSJ Wagoneer
Nice wheels!
Brizio is offline
post #14 of 24 Old 12-20-2008, 09:44 AM
TPI Monte SS
Bling is OK, as long as it's not over-done. It'll handle quite a bit better with the 18s as well, so that's a big bonus. I have a set of TJ steel wheels with 225/75 15 Wrangler GSAs that I use from December-March. They're good in the snow, which we've already had this year in NJ. Gotta be prepared, especially when hauling my wife and kids around.
Originally Posted by Brizio View Post
Nice wheels!
Thanks man!!
'01 XJ - SOLD!
post #15 of 24 Old 12-20-2008, 09:58 AM
madrabbitt
madrabbitt's Avatar
Kinda makes me wonder what the rims would look like on my WJ.
After winter is done, of course.
I've been keeping my eye out for OEM jeep chrome 18 inchers, but not having much luck.
Of course, with the amount of highway miles i drive, 18 inchers with good tires isnt exactly a bad thing.
It would also let me put really aggressive tires on the OEM 16's for when I need it.
biggest tire on stock 15x7 rims?? sedanss Tires & Wheels 26 06-27-2009 01:32 PM
Poll: chrome rims or black rims MC_NickP Tires & Wheels 15 05-31-2009 12:07 AM
Biggest tire size-stock rims? mytjtoy Tires & Wheels 2 03-04-2006 05:07 PM
Whats the Biggest Meats can you run with 15X8 rims? IGotADisneyJeep Tires & Wheels 8 04-25-2005 06:45 AM
Explorer rims=Wrangler rims? SGR1600 Tires & Wheels 5 04-01-2003 07:38 AM
