bent license plate - JeepForum.com
post #1 of 7 Old 10-08-2012, 03:25 PM Thread Starter
LogansRun
bent license plate
Is illegal to bend the license plate around the rear corner of the jeep. I have a YJ that I relocated my fuel bezzle. The pate would still have the stock light so that's not a issue.
94 YJ, 2.5Ltr, SOA, 1 inch BL, 79 F150 HP D44 with an OX Locker, 8.8 LSD, 35x15.50 Goodyear Kevlars, 5.13 gears, CB, SYE, 1 inch motor lift, skid plate spacers removed, Offroad lights, XRC8 winch, and the list goes on.
LogansRun is offline
post #2 of 7 Old 10-09-2012, 02:58 PM
brokenyoujoint
Why not? So long as it can be read. Get cool and rivet it in. If you get a ticket, it's a fix it ticket and just "fix it"
brokenyoujoint is offline
post #3 of 7 Old 10-09-2012, 04:37 PM
rLEEermy
tape leaves to your car so the police mistake it for a bush
rLEEermy is offline
post #4 of 7 Old 10-09-2012, 04:50 PM
biffgnar
biffgnar's Avatar
Have had mine like that for a couple years. Honestly don't think it is legal, but never had a problem with it including once when I got a fix it ticket for the taillight on the opposite side being out (bad ground).
Romney in 2020!
biffgnar is offline
post #5 of 7 Old 10-09-2012, 05:00 PM Thread Starter
LogansRun
Cool. It's going on tonight.
post #6 of 7 Old 10-18-2012, 11:09 AM
printingray
You should fix it anyway.
http://www.printingray.com/
printingray is offline
post #7 of 7 Old 10-25-2012, 11:40 AM
Indy
Indy's Avatar
It will be illegal in most states. But many states have laws on the books that state a plate cannot be modified and must be fully visible at all times. That means many license plate frames are illegal as they cover portions of the plate, parking stickers on the plate are also illegal (had that conversation with a LE when I was in college, that required the sticker to use the college lots. Locally you're supposed to have a front and rear plate, front plate has to be mounted on the exterior of the vehicle so sitting on the dash is a no-no. I've stopped several for lacking the front plate, at least 1 of my vehicles doesn't have one. If I get stopped, I get stopped.
At the end of the day you may never have an issue, but if your laws are similar and LE wants to stop you for some reason, it's all the reason they need.
If you think it's only a fix it ticket, make sure that exists beyond the officers discretion. If it doesn't, the fact it was wrong at the time of the stop = you're paying the fine if the LE doesn't feel the need to dismiss it for you. The offense occurred and fixing it after the fact doesn't mean it didn't happen. There are no fix it tickets in wyoming and 0 mandatory warnings as an example. I did dismiss several over the years but nothing said I had to and gave 100 warnings for every ticket I wrote. I just hated going to court .
I'm the only gay eskimo.
Indy is offline
