Battery Relocation Quick Answer Please!!! - JeepForum.com
post #1 of 9 Old 01-14-2007, 05:42 PM Thread Starter
Jmila1901
Jmila1901's Avatar
I am relocating my battery to the trunk and i want to know if i need to run both the posetive and the negetive back to the engine compartment??? can i just run the negative to the closest ground and call it a day?
Thanks!
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #2 of 9 Old 01-14-2007, 05:50 PM
Rock Kustoms
Rock Kustoms's Avatar
run it back. both of them need to be atleast 2ga.
Rock Kustoms is offline
post #3 of 9 Old 01-14-2007, 05:50 PM
Ivanito
Ivanito's Avatar
You always want your ground to be close to your battery. Make sure you clean off the area you ground it to, as a lot of eletrical probs can be traced to bad grounds.
Addco swaybar for sale
Ivanito is offline
post #4 of 9 Old 01-14-2007, 05:57 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Relocating as in having only one battery in the trunk, and none n the engine bay?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 9 Old 01-14-2007, 07:55 PM Thread Starter
Jmila1901
Jmila1901's Avatar
Yeah, im actually doing this on a mustang in order to gain more room for twin turbos... I figured it would be the same as on the Jeep... But i am just going to have 1 battery in the trunk
Justin Mila
post #6 of 9 Old 01-14-2007, 08:38 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Run both wires back, and sand down the ground in the engine bay.
use 1/0 wire.
-Matt
White '94 YJ Sport
UltimatE is offline
post #7 of 9 Old 10-14-2011, 09:20 PM
thisguyhasadd2
how much would this cost to do on a jeep? i want to clean up the look in the engine bay and move mine to the trunk too
thisguyhasadd2 is offline
post #8 of 9 Old 10-31-2011, 05:06 PM
snail81
Do not run two cables. You can ground it to the frame in the back. Just clean before you attach.
snail81 is offline
post #9 of 9 Old 11-13-2011, 06:46 AM
superj
BMW has their batter in the back from the factory. One thick main power runs to the front and the battery is grounded back in the trunk. Their cars are all electronic and no issues with that set up so imagine it would work fine in anything else too
I don't feel like working on anything at this time so i sold my yj.
superj is offline
Exhaust question - need a quick answer nbrege Engines & Drivetrain 1 04-11-2009 11:41 AM
Bestop Products - Just need a quick answer! IMYY4U General Jeep & Off-Road Equipment 1 07-19-2007 06:41 PM
Need Quick Answer... Unplugging Antenna from Stereo grogie Audio, CB & Ham Radios, GPS, & Electrical 6 06-09-2006 06:17 PM
Need Quick Answer!! CherokeeLmt98 Tires & Wheels 8 10-19-2005 06:08 PM
Load rating for tow straps...quick answer Dfalcon16 General Jeep & Off-Road Equipment 6 08-01-2003 05:28 PM
