AW4 Shift Kit - JeepForum.com
post #1 of 36 Old 02-27-2008, 04:37 PM Thread Starter
alexrule123
alexrule123's Avatar
AW4 Shift Kit
Well I was bored at work and came across this from a Supra Forum
http://supraforums.com/forum/showthread.php?t=267655
How to make a a340 last(56kers take a nap)
**EDIT** Just linking this thread to answer some quick questions. http://www.supraforums.com/forum/sho...=408088&page=2 Zazzn.
These are my own little tricks to make a a340 last. If you are rebuilding it, or having it rebuilt, install kevlar clutches, they tend to do best. Also, you must have a larger cooler on your car! Heat kills 90% of these transmissions. The other trick is to lock the detent(kick down cable) in full open, and to shim two of the accumulators, which is the only true way of decreasing shift time. this well affect the 1-2 and 2-3 shifts. Here's a brief walk through of that process...
Im in the process of making a full website with more intensive photos and walkthrough, stay tuned
After having one servere issue arise(we are working to correct it) I must strongly advise the following points.
1: It is best to do this mod with the transmission out of the car, the time saved by just pulling it will payoff on assembly
2: Get a new gasket, they are VERY sensitive to dust and such and can distort and bleed pressure
3: DO NOT OVER TOURQUE THE BOLTS. This is CRUICIAL you can warp the valve body or the transmission case when you do this. The spec is around INCH LBS, No airtools allowed for the valve body!
4: Do not mix your bolts up, they go in certain places.
The issue that has arrisen is a car shifting into reverse when it should go into overdrive, and it appears to be a pressure bleedoff issue, once we have that exact cause located, I will post it, and ways to avoid it.
Remove transmission(my preference)
Remove the transmission pan bolts, I marked most of them, you can figure it out...
Remove the filter with the three marked bolts. Also there are two metal tubes, I already had them out so I drew them in, gently pry back and forth and they will come out
The fun part, my recommendation is do not take the bolts out of the valve body, they are specific on their location.
Completely loosen the brown arrows, loose till there is slack on the bracket for the purple arrow, and remove electrical connectors marked by blue. Before you can remove the valve body, you must disconnect the kick down cable, see next picture to see the bottom side of it
This is what everything looks like once you get the valve body off, The two "things" marked are accumulators, those two are the only ones we are concerned with at this time
A close up of the accumulators
This is the first accumulator stretched out, the trick to getting them out is to push them all the way down and let them pop up... only way I can get them out.(this is the b-2 accumulator 1-2)
This is the bottom side of the accumulator(the one without the solid rod, that would be put in first going back in) This is where you want to place your shims, you want the shims to be about 1/3 of the spring travel, unless you don't care about you neck and you're tires breaking loose every shift.
Make 100% sure that you do not block this port, if you do, you're screwed.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #2 of 36 Old 02-27-2008, 04:39 PM Thread Starter
alexrule123
This is the c-2 accumulator 2-3 see above for details
inside c-2 place shims as above
Again, don't block this port
This is just a reference picture, of how far the travel is, but you'll be figuring that out on you're own.
again reference, this is the outside of the tranny, to from the right, b-2,c-2, then the kick down cable.
Final reference, on reassembly, make sure this is how the shift lever looks, otherwise it won't work.. =)
Final note, the easiest way of locking the kick down full open is to cut the cable(with valve body and transmission fully together) and then lock it with a cable lock or other vising device, unless you want to build a wedge to put in when the valve body is out, all a matter of preference.
Not too descriptive, but I hope this at least will give you all an idea of where to start with when upgrading a a340. Also, I don't see much need of a upgraded valve body, from what Ive researched, they are rarely more then what you can do you're self here, or slightly enlarged passages, not worth the money to me.
So what do you guys think?
post #3 of 36 Old 02-27-2008, 07:36 PM
SilverXJ
Yeah.. that sounds really bad. I'll think I will skip this mod.
SilverXJ is offline
post #4 of 36 Old 02-27-2008, 09:55 PM
jlaudiojeep
Nice work. That is a process thou, what was ur build time
jlaudiojeep is offline
post #5 of 36 Old 02-27-2008, 10:08 PM Thread Starter
alexrule123
no they fixed it, they had some of the springs in the wrong places
Here is the quote
Shimming the accumulators makes shift time shorter, locking the detent open increases line pressure, which makes the "harder" shift. You will feel more from the shimmed accumulators, but they work best togather.
And for the problem transmission, that would shift into Reverse when going into O/D was caused by a C-0 accumulator spring installed in the wrong side. We'll get more information on it later, when I have some more time to get pictures and such..
post #6 of 36 Old 02-28-2008, 10:56 AM Thread Starter
alexrule123
I haven't done it yet, but I am really thinking about it
post #7 of 36 Old 02-28-2008, 01:49 PM
seanyb505
1997 XJ Cherokee
You guys and your automatics...
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's.
Projected date of completion - lol
seanyb505 is offline
post #8 of 36 Old 02-28-2008, 09:50 PM
jlaudiojeep
i would shoot myself if i had a manual dd, thats what my bimmer is for...lol
post #9 of 36 Old 02-28-2008, 10:12 PM
d768
1991 XJ Cherokee
wait so this is for rebuilding and making it shift faster? isnt it better to control it yourself? with the thing from the other thread?
1993 3dr XJ i6 4x4 , in the works but road-going :p
MY THREADS
d768 is offline
post #10 of 36 Old 02-29-2008, 05:16 AM
n20jeep
n20jeep's Avatar
1993 XJ Cherokee
no........
n20jeep is offline
post #11 of 36 Old 02-29-2008, 09:10 AM Thread Starter
alexrule123
just to shift faster
post #12 of 36 Old 03-01-2008, 01:41 PM
kingofthehill
1990 XJ Cherokee
other thread?
what the supra guy is doing is making is so when you shift from 1-2 and 2-3 the pause (you know when you stop accelerating for that breif moment) when you shift (an auto)is much shorter. That would be unpleasent for most people that (and the shorter clutch pack life) is why the factory didn't make the trans do that
90' XJ 2dr 2wd
Curent issues:
OMFG you don't even want to know
kingofthehill is offline
post #13 of 36 Old 03-03-2008, 10:22 AM
GrayBomb
1989 XJ Cherokee
Originally Posted by kingofthehill View Post
other thread?
Quicker shifts, up to a point, means less clutch slipping and longer clutch pack life. It is up to a certain point though. I will do this mod with small shims once I get my new trans and up the pressure.
For Sale: 89' Limited w/ Renix. Performance:Custom Cold Air Intake, Air Temp Conversion, Map Adjuster, Throttle Body Conversion Bored, 99+ intake manifold, 98 injectors w/ 99 fuel rail, bumped fuel pressure, Borla Wrapped Header, 2.5 in exhaust header back, open loop cooling, electric fan conversion, SS brake lines, 96+ brake booster and still getting 20 mpg highway
GrayBomb is offline
post #14 of 36 Old 03-25-2008, 05:04 PM
Rock Kustoms
Rock Kustoms's Avatar
yes, the clutches will last longer, i just had the TV cable opened all the way on my jeep, it was pretty firm, but makes no difference at WOT, because thats how it was normally at WOT
Rock Kustoms is offline
post #15 of 36 Old 03-26-2008, 12:36 AM
kingofthehill
1990 XJ Cherokee
^^I did not know that
90' XJ 2dr 2wd
Curent issues:
Can't shift into four low dwywllms General Jeep & Off-Road Equipment 5 09-24-2009 02:24 PM
XJ AW4 TCU Shift Mod LEAD_NOT_FOLLOW Technical Articles & Write-Ups 1 02-02-2009 09:24 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
Shift kit for 6 spd 2005 TJ??? JackMJeep Engines & Drivetrain 1 06-11-2006 05:15 PM
AW-4 SHift kit rob92xj Engines & Drivetrain 1 02-05-2006 06:49 PM
