Acceleration - JeepForum.com
post #1 of 15 Old 02-04-2013, 11:53 AM Thread Starter
brh5073
Acceleration
I am a new jeep owner. I just got my jeep two days ago and i have a question about its acceleration. I was on the highway in 6th going 70 the i came to a slight hill and i was having a hard time and started to slow down so i put it in 5th and it continued to have a hard time and continued to have a hard time. It stayed around 45 as it climbed the hill with my foot to the floor hitting the gas. Same thing happened when i was climbing a hill going 35 in 3rd gear.
I was also on a flat straightaway and wanted to see how long it would take me to go from 65 to 70 and in 6th it took about 45 secs and in 5th took about 35-40 secs. Is this normal for a jeep?
brh5073 is offline
post #2 of 15 Old 02-04-2013, 11:54 AM
biffgnar
biffgnar's Avatar
What kind of jeep? What transmission? What tire size? What axle gearing?
Romney in 2020!
biffgnar is offline
post #3 of 15 Old 02-04-2013, 12:31 PM Thread Starter
brh5073
Sorry I thought I said it. It a 6 speed manual transmission on a 2009 Sahara. I can not remember what size the tires are but I think they are the stock tires. There is about 14k miles on the car.
brh5073 is offline
post #4 of 15 Old 04-09-2013, 09:00 PM
SKELITOR117
What engine size dude? Details details details. I can get the info you want but I need some first.
SKELITOR117 is offline
post #5 of 15 Old 04-19-2013, 12:33 PM
rubi513
I am guessing that you have the 3.8 because the 4 cylinder was not offered for the jk. At least I don't think it was. And no your truck should not be that slow. Even with 35's and 3.07 gears I would think it would be faster than what your stating.
rubi513 is offline
post #6 of 15 Old 04-19-2013, 12:49 PM Thread Starter
brh5073
3.8l the acceleration is ok now but going up to school i have a hard time going up the mountain. Also my 2nd gear sync seems like its going.
brh5073 is offline
post #7 of 15 Old 04-19-2013, 05:19 PM
222Doc
222Doc's Avatar
What no one is a clairvoyant here.
222Doc is offline
post #8 of 15 Old 04-19-2013, 08:25 PM Thread Starter
brh5073
I mean i figured you guys would know what a stock JK has. 3.21 gear ratio, 6 speed manual, i believe 33 inch tires. Like i said its a 2009 sahara.
brh5073 is offline
post #9 of 15 Old 04-19-2013, 10:34 PM
222Doc
222Doc's Avatar
No offense just poken you a bit.
they did not come 33". are the 12.5 wide? if so they are after market.
3.8's are very picky on gears. Jeep should have never used 3:21 gears. those that did get them came with like 29-30"s? and they are street tires. Most people end up with 4:88/5:13 for 33/35". 3.8 is well known to be lacking in torque. Off road it does ok but that is by gear reduction.
if you have 33"s then that is thetrouble. Need a regear. That will help the MPG, alittle.
It helps to fill out the INFO page on the Jeep in your profile.
222Doc is offline
post #10 of 15 Old 04-20-2013, 01:36 AM Thread Starter
brh5073
I meant to say 32 inch tires which i believe are the stock size tire. I will check when i get the chance tomorrow. I do want to regear butamnit looking forward to replacing the front axle. Why would Chrysler make a small front axle that couldnt take the bigger gears? I plan on going with a 4.10 ratio and get 35s with a 3.5-4 inch lift. Thats a while a way though. I need to make some money first. Can anyone suggest a good lift kit that wont break the bank?
brh5073 is offline
post #11 of 15 Old 04-20-2013, 08:38 AM
222Doc
222Doc's Avatar
You could run the D30( cromo axles at least). I know many that do and they run hard trails. It depends on the right foot mod. You could find a take off from Rubi for much less than a new D44. Re gearing is getting expensive I feel your pain.
I think you can get upto 5:13 in the D30 but the Pin is very small.
Not a Tj guy, I went from a Cj to a Jk. But you get what you pay for, in Jeeps that is even more so. Cheeper lifts have cheep springs and parts. But this depends on what are you planning to do. Getting into wheeling and that leads to harder trails in the end for many. Jus a DD and looks is important.
222Doc is offline
post #12 of 15 Old 07-13-2013, 11:31 PM
Spud100
Slow... Welcome to jeep world.
Spud100 is offline
post #13 of 15 Old 08-28-2013, 06:37 PM
WJefy
Your acceleration doesn't sound normal, especially with stock tire size. Check your air filter. If it stinks like sulfur after a hill climb, I'd also suggest checking the catalytic converter. Your description makes me think something is keeping the engine from breathing. Any heavy black smoke coming out the back?
WJefy is offline
post #14 of 15 Old 09-01-2013, 09:01 PM
superj
The two wheel drive jku have 4.10 gears stock in their rear axle. Find and and swap it on the back and then just swap the front to match. That should help. My wife's 2x4 07 jku is pretty damn quick light to light and does just fine in the hills and highway passing
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #15 of 15 Old 09-03-2013, 09:54 PM
Spud100
For the most part, factory gears are too high (to optimize gas mileage). Add some larger tires and it becomes a dog. Regearing will be the best money you will ever spend. Mine came with low 4:10s which is pretty low, but I'm considering going even one size lower.
Spud100 is offline
