Ac problem - JeepForum.com
post #1 of 6 Old 07-27-2012, 08:44 AM Thread Starter
Cross6969
Ac problem
I have a 93 jeep
Cross6969 is offline
post #2 of 6 Old 07-27-2012, 09:25 AM
ajmorell
ajmorell's Avatar
mmk
ajmorell is offline
post #3 of 6 Old 07-27-2012, 09:50 AM Thread Starter
Cross6969
Ok..... Hi everyone I have a. 93 jeep grand Cherokee 6cyl 4.0. I replace the condensor, compressor, ac relay switch, accumulator/ drier. The car get cold when it not hummus, but when it hits 80 or better it gets hot. What am I missing to correct problem !
post #4 of 6 Old 12-11-2012, 06:48 PM
gumby_144
are you sure that the refrigerant charge is correct. also check to make sure there isnt a drier in the system that is pluged or that the metering device isnt pluged.
gumby_144 is offline
post #5 of 6 Old 12-19-2012, 04:42 PM
crcycle44
There's several different factors that could be your problem.Did you have a compressor failure,if not why did you replace Compressor?
crcycle44 is offline
post #6 of 6 Old 12-20-2012, 08:57 PM
narnwv
narnwv's Avatar
was a vacuum pulled on the system before it was charged?
~Aaron
narnwv is offline
