AC Failure - JeepForum.com
post #1 of 4 Old 07-18-2012, 03:02 PM Thread Starter
sablak
2001 FSJ Cherokee
AC Failure
Given the recent spike in temperature I tried the AC on a recently purchased gently used '01 Cherokee Sport. It worked fine for about five minutes, then the cool air stopped, replaced by a warm and humid air flow. Does anyone have any idea as to the problem?
sablak is offline
post #2 of 4 Old 07-26-2012, 10:37 AM
narnwv
narnwv's Avatar
check out the compressor. Does it kick on then go off (resulting in the warm then hot air)?
Report back.
Also, your 2001 Cherokee would be an XJ, not a FSJ as listed in your profile. Changing that will allow others to help better in the future.
~Aaron
narnwv is offline
post #3 of 4 Old 09-10-2012, 06:52 PM
COLOUXJ
2010 JK Wrangler
Sounds like you have a pressure issue with the R-134, you either do not have enough, you have to much, or the system is blocked. My cherokee used to do that when I was sitting still because the pressure spiked as the condenser could not cool the R-134
COLOUXJ is offline
post #4 of 4 Old 10-24-2012, 04:21 PM
ericg2000
Not sure if this is the same but my 90 yj ac will blow cold then randomly warm up. I had the freon checked and topped off. I've read other threads and they say my rpm's are too low. So I hit the gas some and the air cools off again. Do I have a problem or is this just how it goes with these ac systems?
ericg2000 is offline
AX5 failure (5th gear) ACSJeep2000 Engines & Drivetrain 5 01-27-2012 01:47 AM
XJ OD failure XJeepFace Engines & Drivetrain 0 11-03-2011 08:10 PM
pre cat failure? ajamison Engines & Drivetrain 4 08-16-2010 04:35 PM
02 sensor failure Shanker67 Engines & Drivetrain 9 06-03-2010 07:54 AM
Help: 4.0L I6 Failure Brian's 97 ZJ Engines & Drivetrain 4 03-02-2004 01:54 PM
