600hp Transmission/Transfer Case - JeepForum.com
post #1 of 8 Old 02-14-2014, 07:46 PM Thread Starter
BCrawford64
Hi everybody I was wondering if there are any people on here that have swapped trans/transfer cases in their jeeps for higher hp applications. I was thinking about full manual valve body 700r4 and NP205. But I the NP205 is really heavy and way more than I would need. Also how hard would it be to wire in a 4L60e and the matching transfer case (I know its lighter). Would combination would you recommend. I already have the motor situation figured out, but it's a secret until I post it on my build page. Remember trying to stay as light an strong as I can. Thank you for the help!
BCrawford64 is offline
post #2 of 8 Old 02-15-2014, 07:50 AM
AFRd_CJ5
1976 CJ5
I ran a th350/ Dana 300 tcase behind well over 600HP for a number of years. OD would be great, but depending on the application, it might not be needed and you can go the old simple route.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #3 of 8 Old 02-15-2014, 10:38 AM Thread Starter
BCrawford64
Yeah I was looking into the dana 300 last night and it seemed like a great option. Substantially lighter than the NP205 and its really all that I'll need.
post #4 of 8 Old 02-16-2014, 04:01 PM
AFRd_CJ5
1976 CJ5
What are your plans with the Jeep?
'76 CJ5
AFRd_CJ5 is offline
post #5 of 8 Old 02-17-2014, 05:54 AM Thread Starter
BCrawford64
What I'm trying to shoot for is a daily driver/sleeper. It's going to be lifted (3.5" Rusty's Kit). I want to be able to race it, drive it to work, college, and be able to still take it mildly offroad. Plus where I live we get a good amount of snow each year so a decent lift with a lot of power should make it fun. And possibly take it to the dunes. Havn't been there but I've always wanted to go.
The modifications I want to do are D30 HP Front (4.56 Locker, Yukon Shafts, Artec Truss), Ford 8.8 Rear (4.56 Locker/Spool, C-Clip Elimination, Artec Swap Truss) 4.0 Stroker w/ Holset HX35w Turbo, 700r4 Trans (TCI full rebuild, Manual Valve Body, Maybe transbrake), Dana 300, Stich weld panels and structurally re-enforce unibody, Roll Cage, Rigid light bar, and Bumpers.
post #6 of 8 Old 02-17-2014, 06:41 AM
AFRd_CJ5
1976 CJ5
Sounds like a solid plan. Shoot me a PM if you do a build thread so I'm aware of it in case I don't see it. Definitely interested in how the 4.0/turbo setup goes. We are at the dunes quite a bit, you'll definitely have fun with some good HP in the sand!
I run a 30 with Yukon shafts in it and some good HP. Never had any issues, but the real hard abuse is always done in the sand.
'76 CJ5
AFRd_CJ5 is offline
post #7 of 8 Old 02-17-2014, 02:22 PM Thread Starter
BCrawford64
Alright, will do.
post #8 of 8 Old 07-29-2014, 07:49 PM
Scott_B
1995 XJ Cherokee
I have an APS super torque twister 46RE Mopar transmission ta is actually or sale... I had an engine fire that took u my ignition and wiring harness. I am in the process of rebuilding this vehicle with a big block and a 727 so this trans is up for sale: https://post.craigslist.org/manage/4577651777
Scott_B is offline
